[postgis-users] PostGIS mapbox vector tiles and custom tile grid
Raúl Marín Rodríguez
rmrodriguez at carto.com
Mon Apr 1 01:46:32 PDT 2019
Can you share the query and some minimal test case that shows the issue?
> Sometimes I use raw 3D-model data without any wellknown coord system.
Keep in mind that, in ST_AsMVTGeom, both the geometry and the bounding box
(first and second arguments) should use the same SRID / coordinate system,
and that only 2 dimensions are used to generate the resulting geometry.
Regards,
carto.com
