[postgis-users] PostGIS mapbox vector tiles and custom tile grid
Raúl Marín Rodríguez
rmrodriguez at carto.com
Tue Apr 2 00:22:14 PDT 2019
> How do you think I can optimize it?
It's highly likely that you want to inline the CTE and, you can remove
one of the intersections (&& or ST_Intersects); ST_Intersects already
calls && implicitly so you could choose to only use that, but I'd recommend
using && instead; then you can either discard NULLs or pass it to ST_AsMVT
and it will get discarded automatically.
Also, AFAIK ST_FORCE2D shouldn't be necessary so I'd only call it in you
see something odd.
Another thing to discard is ``ORDER BY`. Since order isn't guaranteed
in ST_ASMVT
output, if you are going to pass this result to it I'd remove the `ORDER BY`.
Finally, make sure you don't need the extra buffer (4th parameter of
ST_AsMVTGeom).
It's useful in some renderers to help stitching the polygons back
together (but not mandatory).
The result query could look something like this:
```SELECT
id
, ST_ASMVTGEOM(
geometry,
ST_MAKEENVELOPE(:min_x, :min_y, :max_x, :max_y),
:tile_size, 0, true) geometry
FROM
SELECT
id
, original_feature_id
, layer_id
, geometry
FROM {0}.{1}
) _subquery
WHERE layer_id = :layer_id
AND geometry && ST_MAKEENVELOPE(:min_x, :min_y, :max_x, :max_y)
) q
carto.com
