[postgis-users] Lib size issue
    Fan Liu
    fan.liu at ericsson.com
    Tue Apr  2 00:34:49 PDT 2019
Thanks, Raul. I will working on it.
BRs,
Fan Liu
-----Original Message-----
From: postgis-users <postgis-users-bounces at lists.osgeo.org> On Behalf Of Raúl Marín Rodríguez
Sent: Tuesday, April 2, 2019 3:28 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] Lib size issue
Hi Fan,
You should probably ask in the gdal mailling list but I'd bet your compilation includes debugging symbols.
As a reference, in my system gdal 2.3.2 takes 17M without symbols and
117 with them.
If you don't need them you can either remove them from your CFLAGS
(-gX) and recompile
or strip them from the compiled library (`strip -s libgdal.so.20.5.0`).
Note that depending on the distribution you might have packages with just the symbols available (*-dev or something like that).
carto.com
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
