[postgis-users] diffrent execution plan on Postgres 9.5 and Postgres 11 for ST_union and performance problem Postgres 11
Lars Aksel Opsahl
Lars.Opsahl at nibio.no
Thu Apr 11 03:27:15 PDT 2019
Hi
We are upgrading from Postgres 9.5 to Postgres 11 and have a problem with ST_Union query.
It used around 5 minutts on Postgres 9.5 but on the Postgres 11 it takes around a hour.
This is two different physical servers.
* Postgres 11 server (Intel(R) Xeon(R) Gold 6126 CPU @ 2.60GHz), is running Redhat 7.0
* Postgres 9.5 server ( Intel(R) Xeon(R) CPU E5-2667 v2 @ 3.30GHz) is running Cent 6.9 .
The only index on table in the geo column
* Sql and query plan for from Postgres 9.5
POSTGIS="2.2.2 r14797" GEOS="3.5.0-CAPI-1.9.0 r4084" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.6" LIBJSON="0.11" TOPOLOGY RASTER
sl=# EXPLAIN ANALYZE
sl-# select atil, myr, myrtype,myromdanning,myrtypetext,myromdanningtext
sl-# , st_union(geo) as geo
sl-# from sde_markslag.markslag_myrikilden_temp
sl-# group by atil, myr, myrtype,myromdanning,myrtypetext,myromdanningtext ;
QUERY PLAN
QUERY PLAN
GroupAggregate (cost=796867.85..1683469.04 rows=170173000 width=1668) (actual time=20548.994..386236.175 rows=482885 loops=1)
Group Key: atil, myr, myrtype, myromdanning, myrtypetext, myromdanningtext
-> Sort (cost=796867.85..801122.16 rows=1701723 width=1668) (actual time=19215.245..28191.175 rows=567241 loops=1)
Sort Key: atil, myr, myrtype, myromdanning, myrtypetext, myromdanningtext
Sort Method: external merge Disk: 834880kB
-> Seq Scan on markslag_myrikilden_temp (cost=0.00..180364.23 rows=1701723 width=1668) (actual time=0.115..2625.401 rows=567241 loops=1)
Planning time: 1.942 ms
Execution time: 386479.469 ms
(8 rows)
* Sql and query plan from Postgres 11
POSTGIS="2.5.2 r17328" [EXTENSION] PGSQL="110" GEOS="3.7.1-CAPI-1.11.1 27a5e771" SFCGAL="1.2.2" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 1.11.4, released 2016/01/25" LIBXML="2.9.1" LIBJSON="0.11" TOPOLOGY RASTER
EXPLAIN ANALYZE
QUERY PLAN
Result (cost=69528.63..120459.99 rows=192000 width=46) (actual time=962.266..3272057.295 rows=482885 loops=1)
-> ProjectSet (cost=69528.63..70539.99 rows=192000 width=46) (actual time=962.262..3272011.001 rows=482885 loops=1)
-> HashAggregate (cost=69528.63..69531.03 rows=192 width=46) (actual time=962.214..3268248.140 rows=166 loops=1)
-> Seq Scan on markslag_myrikilden_temp (cost=0.00..59601.91 rows=567241 width=1614) (actual time=0.012..336.203 rows=567241 loops=1)
Planning Time: 0.163 ms
Execution Time: 3272080.299 ms
(7 rows)
So on Postgres 9.5 we see groupAggregate but not on postgres 11.
If I on postgres 11 tests with ST_collect it's very fast, bu we can not use that result.
EXPLAIN ANALYZE
select atil, myr, myrtype,myromdanning,myrtypetext,myromdanningtext , (ST_dump(st_Collect(geo))).geom as geo
QUERY PLAN
Result (cost=69528.63..120459.99 rows=192000 width=46) (actual time=934.723..5611.094 rows=567241 loops=1)
-> ProjectSet (cost=69528.63..70539.99 rows=192000 width=46) (actual time=934.720..5556.601 rows=567241 loops=1)
-> HashAggregate (cost=69528.63..69531.03 rows=192 width=46) (actual time=934.684..1554.725 rows=166 loops=1)
-> Seq Scan on markslag_myrikilden_temp (cost=0.00..59601.91 rows=567241 width=1614) (actual time=0.012..335.069 rows=567241 loops=1)
Planning Time: 0.179 ms
Execution Time: 5629.207 ms
(7 rows)
Can it be problem related ST_Union and aggregate ?
I have tested with and with out indexes on atil, myr, myrtype,myromdanning,myrtypetext,myromdanningtext and it does not make any difference .
Lars
Thanks
Lars
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190411/b007f605/attachment.html>
