[postgis-users] diffrent execution plan on Postgres 9.5 and Postgres 11 for ST_union and performance problem Postgres 11
Paul Ramsey
pramsey at cleverelephant.ca
Thu Apr 11 12:16:08 PDT 2019
something like
select encode(st_asbinary(st_collect(geom)), 'hex') from mytable where
id < 10000
just a nice hex-encoded wkb
p
On Thu, Apr 11, 2019 at 12:11 PM Martin Davis <mtnclimb at gmail.com> wrote:
> Yes, that's exactly the test needed. So it looks like ST_Union(agg) on the 11 instance is much slower than on 9.5:
> 11: 25335.136 ms
> 9.5: 4409.919 ms
> The question is why... We'll have a look and see if there's any regression in GEOS (which is what is performing the union).
> Are you able to share the dataset from the above test? (As a file of WKT or WKB)
> On Thu, Apr 11, 2019 at 11:55 AM Lars Aksel Opsahl <Lars.Opsahl at nibio.no> wrote:
>> Hi
>> Do mean something like this ?
>> Here is the result from postgres 11 -
>> EXPLAIN ANALYZE
>> select (ST_dump(st_union(geo))).geom as geo
>> from sde_markslag.markslag_myrikilden_temp
>> where gid < 10000
>> QUERY PLAN
>> Result (cost=62634.26..62899.53 rows=1000 width=32) (actual time=25249.956..25331.325 rows=9205 loops=1)
>> -> ProjectSet (cost=62634.26..62639.53 rows=1000 width=32) (actual time=25249.953..25330.483 rows=9205 loops=1)
>> -> Aggregate (cost=62634.26..62634.28 rows=1 width=32) (actual time=25244.718..25244.719 rows=1 loops=1)
>> -> Seq Scan on markslag_myrikilden_temp (cost=0.00..62609.51 rows=9900 width=1593) (actual time=0.008..173.033 rows=9999 loops=1)
>> Filter: (gid < 10000)
>> Rows Removed by Filter: 557242
>> Planning Time: 0.064 ms
>> Execution Time: 25335.136 ms
>> (8 rows)
>> Here is the same postgres 9.5 -
>> EXPLAIN ANALYZE
>> [more] - > select (ST_dump(st_union(geo))).geom as geo
>> [more] - > from sde_markslag.markslag_myrikilden_temp
>> [more] - > where gid < 10000
>> [more] - > ;
>> QUERY PLAN
>> Aggregate (cost=170462.27..170467.28 rows=1000 width=1604) (actual time=4311.911..4409.250 rows=9205 loops=1)
>> -> Seq Scan on markslag_myrikilden_temp (cost=0.00..170437.51 rows=9903 width=1604) (actual time=0.054..629.045 rows=9999 loops=1)
>> Planning time: 0.045 ms
>> Execution time: 4409.919 ms
>> (6 rows)
>> Thanks
>> Lars
>> ________________________________
>> From: postgis-users <postgis-users-bounces at lists.osgeo.org> on behalf of Martin Davis <mtnclimb at gmail.com>
>> Sent: Thursday, April 11, 2019 8:07 PM
>> To: PostGIS Users Discussion
>> Subject: Re: [postgis-users] diffrent execution plan on Postgres 9.5 and Postgres 11 for ST_union and performance problem Postgres 11
>> On Thu, Apr 11, 2019 at 3:27 AM Lars Aksel Opsahl <Lars.Opsahl at nibio.no> wrote:
>> Can it be problem related ST_Union and aggregate ?
>> Can you test the performance of aggregate ST_Union on it's own by dropping the GROUP BY and instead using a WHERE clause to union a small-ish subset of the geometries? (But large enough to give a measurable query time.)
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
