[postgis-users] Error on PostGIS
Pradeep Kanth G pgundala at avineonindia.com
Fri Aug 2 03:17:57 PDT 2019
Thanks, now it is in progress.
Getting the below error
In file included from lwgeom_sfcgal.c:26:0:
lwgeom_sfcgal.h:28:34: fatal error: SFCGAL/capi/sfcgal_c.h: No such file or directory
#include <SFCGAL/capi/sfcgal_c.h>
compilation terminated.
make[1]: *** [lwgeom_sfcgal.lo] Error 1
make[1]: Leaving directory `/root/postgis-2.5.2/liblwgeom'
make: *** [all] Error 1
Regards
Pradeep Kanth
From: postgis-users <postgis-users-bounces at lists.osgeo.org> On Behalf Of Darafei "Kom?pa" Praliaskouski
Sent: Friday, August 2, 2019 3:36 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] Error on PostGIS
This file is shipped as part of Proj library. If you are installing it via your package management system, make sure you're installing libproj-dev (in Debian-like) or proj-devel (in RPM-like).
On Fri, Aug 2, 2019 at 12:59 PM Pradeep Kanth G <pgundala at avineonindia.com <mailto:pgundala at avineonindia.com> > wrote:
I have tried but not getting this file. Kindly let us know, where we have to get?
Regards
Pradeep Kanth
From: postgis-users <postgis-users-bounces at lists.osgeo.org <mailto:postgis-users-bounces at lists.osgeo.org> > On Behalf Of Darafei "Kom?pa" Praliaskouski
Sent: Friday, August 2, 2019 3:28 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org> >
Can you check that development headers of proj are actually available, looking for proj_api.h in your file system?
On Fri, Aug 2, 2019 at 12:55 PM Pradeep Kanth G <pgundala at avineonindia.com <mailto:pgundala at avineonindia.com> > wrote:
Installed latest(PostGIS2.5.2 & GEOS 3.7.2) version, but getting the same error.
configure: error: could not find proj_api.h - you may need to specify the directory of a PROJ.4 installation using --with-projdir
Regards
Pradeep Kanth
Sent: Friday, August 2, 2019 3:06 PM
Hello,
PostGIS 2.2 is End of Life. Current release is 2.5.2.
GEOS 3.3 is End of Life. Current release is 3.7.2.
Please consult this matrix when choosing the best versions combinations:
https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
On Fri, Aug 2, 2019 at 12:33 PM Pradeep Kanth G <pgundala at avineonindia.com> wrote:
Trying on below versions..
postgis-2.2.1
geos-3.3.5
gdal-1.9.1
Installed proj-4.8.0 , proj-4.9.1 and proj-5.2.0 but no luck.
Regards
Pradeep Kanth
Sent: Friday, August 2, 2019 2:40 PM
Hello,
what are the versions of proj and postgis that you are using?
On Fri, Aug 2, 2019 at 12:03 PM Pradeep Kanth G <pgundala at avineonindia.com <mailto:pgundala at avineonindia.com> > wrote:
Dear All,
While installing the PostGIS, getting the below error.
./configure --with-pgconfig=/home/postgres/pgxl/bin/pg_config
Error:
make: *** [GNUmakefile] Error 1
Verified PROJ.4 already installed my machine . Kindly let us know go to overcome this issue.
Regards
Pradeep Kanth
Disclaimer | The information contained in this electronic message (including any attachments) is intended for the exclusive use of the addressee(s) and may contain confidential or privileged information.If you have received this in error, please notify the sender immediately and delete the material from your machine. Any  action including review, retransmission, dissemination of this email or the attachments present along with the email by persons or entities other than the intended recipient is prohibited.
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190802/48ce2e4f/attachment.html>
