[postgis-users] Error on PostGIS
Darafei "Komяpa" Praliaskouski me at komzpa.net
Fri Aug 2 03:59:42 PDT 2019
To cross check your actions please have a look at this definitely working
recipe:
https://github.com/postgis/postgis-build-env/blob/master/Dockerfile#L49
You may also want to utilize prebuilt distribution provided packages, say,
from Ubuntu 19.04 or Debian Sid.
On Fri, Aug 2, 2019 at 1:53 PM Pradeep Kanth G <pgundala at avineonindia.com>
wrote:
> Hi,
> I have downloaded but I am not able to install.
> Followed below steps .
> Downloaded the file.
> [root at node1 SFCGAL-1.3.7]# cmake -DCMAKE_INSTALL_PREFIX:PATH=/usr/local
> -CMake Error: The source directory "/root/SFCGAL-1.3.7/build" does not
> appear to contain CMakeLists.txt.
> Specify --help for usage, or press the help button on the CMake GUI.
> Regards
> Pradeep Kanth
> *From:* postgis-users <postgis-users-bounces at lists.osgeo.org> *On Behalf
> Of *Darafei "Kom?pa" Praliaskouski
> *Sent:* Friday, August 2, 2019 3:49 PM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] Error on PostGIS
> Hi,
> Please install SFCGAL and its dependencies, as suggested by the error.
> Current version of libsfcgal is 1.3.7.
> On Fri, Aug 2, 2019 at 1:16 PM Pradeep Kanth G <pgundala at avineonindia.com>
> wrote:
> Thanks, now it is in progress.
> Getting the below error
> In file included from lwgeom_sfcgal.c:26:0:
> lwgeom_sfcgal.h:28:34: fatal error: SFCGAL/capi/sfcgal_c.h: No such file
> or directory
> #include <SFCGAL/capi/sfcgal_c.h>
> compilation terminated.
> make[1]: *** [lwgeom_sfcgal.lo] Error 1
> make[1]: Leaving directory `/root/postgis-2.5.2/liblwgeom'
> make: *** [all] Error 1
> Regards
> Pradeep Kanth
> *Sent:* Friday, August 2, 2019 3:36 PM
> This file is shipped as part of Proj library. If you are installing it via
> your package management system, make sure you're installing libproj-dev (in
> Debian-like) or proj-devel (in RPM-like).
> On Fri, Aug 2, 2019 at 12:59 PM Pradeep Kanth G <pgundala at avineonindia.com>
> wrote:
> Hi,
> I have tried but not getting this file. Kindly let us know, where we have
> to get?
> Regards
> Pradeep Kanth
> *Sent:* Friday, August 2, 2019 3:28 PM
> Hi,
> Can you check that development headers of proj are actually available,
> looking for proj_api.h in your file system?
> On Fri, Aug 2, 2019 at 12:55 PM Pradeep Kanth G <pgundala at avineonindia.com>
> wrote:
> Hi,
> Installed latest(PostGIS2.5.2 & GEOS 3.7.2) version, but getting the same
> error.
> configure: error: could not find proj_api.h - you may need to specify the
> directory of a PROJ.4 installation using --with-projdir
> Regards
> Pradeep Kanth
> *Sent:* Friday, August 2, 2019 3:06 PM
> Hello,
> PostGIS 2.2 is End of Life. Current release is 2.5.2.
> GEOS 3.3 is End of Life. Current release is 3.7.2.
> Please consult this matrix when choosing the best versions combinations:
> https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
> On Fri, Aug 2, 2019 at 12:33 PM Pradeep Kanth G <pgundala at avineonindia.com>
> wrote:
> Hi,
> Trying on below versions..
> postgis-2.2.1
> geos-3.3.5
> gdal-1.9.1
> Installed proj-4.8.0 , proj-4.9.1 and proj-5.2.0 but no luck.
> Regards
> Pradeep Kanth
> *Sent:* Friday, August 2, 2019 2:40 PM
> Hello,
> what are the versions of proj and postgis that you are using?
> On Fri, Aug 2, 2019 at 12:03 PM Pradeep Kanth G <pgundala at avineonindia.com>
> wrote:
> Dear All,
> While installing the PostGIS, getting the below error.
> ./configure --with-pgconfig=/home/postgres/pgxl/bin/pg_config
> Error:
> make: *** [GNUmakefile] Error 1
> Verified PROJ.4 already installed my machine . Kindly let us know go to
> overcome this issue.
> Regards
> Pradeep Kanth
> *Disclaimer *| The information contained in this electronic message
> (including any attachments) is intended for the exclusive use of the
> addressee(s) and may contain confidential or privileged information.If you
> have received this in error, please notify the sender immediately and
> delete the material from your machine. Any  action including review,
> retransmission, dissemination of this email or the attachments present
> along with the email by persons or entities other than the intended
> recipient is prohibited.
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
> Darafei Praliaskouski
> Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190802/3849084d/attachment.html>
