[postgis-users] [Longest distance between two from list of points?]
Nicklas Avén
nicklas.aven at jordogskog.no
Wed Aug 14 10:25:27 PDT 2019
Hi
Sorry if I misunderstand. But don't we also have all this already in
ST_LongestLine.
It also uses convexhull to reduce points to calculate.
atb
Nicklas
On 8/14/19 6:36 PM, Paul Ramsey wrote:
> It’s pretty easy to synthesize a case where the extrema aren’t (both) on the bounding box.
> I like the idea of using the convex hull to reduce the number of input points to a cross join.
> As pointed out on IRC, we have the code already in place in ST_MinimumBoundingRadius we just aren’t returning all the information necessary to derive the extrema.
> P
>> On Aug 14, 2019, at 9:29 AM, Regina Obe <lr at pcorp.us> wrote:
>> Why wouldn't it get an index assistance? ST_DWithin I would think would be separated apart
>> So if you fill in something like ST_DWithin(a,b, a_distance_you_know_is_legit_for_distance_but biggish)
>> Anyrate as was mentioned on IRC, I think the furthest points since you are dealing with just points should lie on the extent
>> So would be just
>> SELECT ST_LongestLine(ST_Extent(geom))
>> FROM your_table;
>> I would think would give you the answer if you are just dealing with points and don't care which points are furthest.
>> -----Original Message-----
>> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
>> Sent: Wednesday, August 14, 2019 12:00 PM
>> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
>> Subject: Re: [postgis-users] [Longest distance between two from list of points?]
>> I dunno, 10000 * 10000 = a really big number and the join condition on NOT doesn t get an index assist P
>>> On Aug 14, 2019, at 8:58 AM, Regina Obe <lr at pcorp.us> wrote:
>>> I would do a cross join
>>> SELECT a.id As a_id, b.id aS b_id
>>> -- pick a number you know is not the furthest this is just to save some processing, you can skip this and just do a CROSS JOIN but will lose some speed
>>> FROM your_points AS a INNER JOIN your_points AS b ON NOT ST_DWithin(a,b,some_biggish_number)
>>> ORDER BY ST_Distance(a,b) DESC LIMIT 1
>>> Sent: Wednesday, August 14, 2019 11:18 AM
>>> of points?]
>>> Depends on how exact you need the answer. If you re looking for the
>>> extent of the data set, using
>>> SELECT ST_Extent(geom) FROM mytable
>>> will pop put a nice bounds and you can easily pull the width/height of that to get something like the size.
>>> The actual two points that are the furthest, that s harder for sure, I almost think you would need a recursive CTE for that, but with only 10K points, it might not perform too too badly. Basically pick a random point, and then find the furthest point from that one (ORDER BY ST_Distance() DESC LIMIT 1), then use that point as the seed for the next iteration, and repeat until you end up with the same pairing in subsequent iterations.
>>> Maybe someone on the list will feel like writing out an example for
>>> the intellectual glory :)
>>> P.
>>>> On Aug 14, 2019, at 7:15 AM, Sergiusz Pawlowicz <sergiusz at pawlowicz.name> wrote:
>>>> I have about ten thousands of points stored in a postgis database.
>>>> I need to find the longest distance between two of the furthest of
>>>> them from each other, something like bounding box, but let's say
>>>> "bounding line".
>>>> Any suggestions?
>>>> I browse the archives but there was no clearly opensource answer, the
>>>> only one was suggesting some FME-like commercial products.
>>>> Thanks,
>>>> Serge
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
