[postgis-users] [Longest distance between two from list of points?]
Regina Obe
lr at pcorp.us
Wed Aug 14 11:55:36 PDT 2019
Minor typo there
WITH c AS (SELECT ST_ConvexHull(ST_Collect(geom)) AS geom FROM your_points)
SELECT ST_LongestLine(c.geom,c.geom)
FROM c;
-----Original Message-----
Sent: Wednesday, August 14, 2019 2:20 PM
To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
Subject: RE: [postgis-users] [Longest distance between two from list of points?]
Okay -- yah I spoke too soon about the ST_Extent and ST_ConvexHull would be a better option.
I had also forgotten that ST_LongestLine takes two inputs, which we are discussing on IRC to add another proto that takes just one input.
So my revised answer is:
WITH c AS (SELECT ST_ConvexHull(ST_Collect(geom)) AS geom FROM your_points) SELECT ST_LongestLine(c.geom,c.geom);
https://postgis.net/manual-2.5/ST_LongestLine.html
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of J.J. Green
Sent: Wednesday, August 14, 2019 12:21 PM
To: postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] [Longest distance between two from list of points?]
The two points will be on the boundary of the convex hull of the set of points. That should reduce the problem to a size where a brute-force cross-join becomes feasible.
-j
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
