[postgis-users] create holes in ocean polygons with island polygons
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Tue Aug 20 06:38:12 PDT 2019
You're getting a copy of each ocean for each island with that island
removed, and only one gets back into the table. You probably want to remove
an union of all islands from each ocean.
UPDATE public."Ocean"
SET the_geom = coalesce(ST_Multi(ST_Difference("Ocean".the_geom, (select
ST_Union(the_geom) from "Islands" where ST_Intersects( "Ocean ".the_geom,
b.the_geom))), the_geom);
On Tue, Aug 20, 2019 at 4:35 PM <paul.malm at lfv.se> wrote:
> Hi,
> I have a table with ocean polygons and would like to create holes in those
> polygons with an island layer (including island polygons).
> I’ve tried this:
> SET the_geom = ST_Multi(ST_Difference("Ocean".the_geom, b.the_geom))
> FROM "Islands" as b
> WHERE ST_Intersects( "Ocean ".the_geom, b.the_geom)
> Postgresql reports 5 uppdates.
> But there are no holes in the ocean polygons, in the location of the
> islands.
> What are I’m doing wrong?
> Kind regards,
> Paul
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190820/38872799/attachment.html>
