[postgis-users] ArcGIS desktop accessing and reading from PostGIS
Shaozhong SHI shishaozhong at gmail.com
Fri Aug 23 01:36:44 PDT 2019
Hi, Bobb,
A database has many schemas.
A schema is a definition of a data structure.  Many tables can be created
by using this data structure.
Am I right?
Regards,
Shao
On Thu, 22 Aug 2019 at 17:25, Basques, Bob (CI-StPaul) <
bob.basques at ci.stpaul.mn.us> wrote:
> Shao,
> I’ve always thought of a schema as a sub-grouping inside of a database, as
> in a database can contain many schemas.
> Or, from a higher point of view . . .
> Database instances (Postgres, Oracle, MySQL, etc) contain one or more
> databases, and each database can contain one or more schemas . . .
> bobb
> On Aug 22, 2019, at 11:07 AM, Shaozhong SHI <shishaozhong at gmail.com>
> wrote:
> *Think Before You Click: *This email originated *outside *our
> organization.
> Hi, Bobb,
> Thanks.
> A lot of technical terms used are interchangeable.
> Am I right to say this? When a postgreSQL database is created, a data
> structure is created.  This data structure is referred to as a scheme?
> Namely, in this instance, a scheme = a data structure created with
> postgreSQL executables.
> Am I right?
> Regards,
> Shao
> On Thu, 22 Aug 2019 at 16:37, Andy Anderson <aanderson at amherst.edu> wrote:
>> Thanks for the correction, Paul, I guess I’ve been relying on my MySQL
>> experience, which stores user data in the "mysql" database.
>> — Andy
>> On Aug 21, 2019, at 12:59 PM, Paul Ramsey <pramsey at cleverelephant.ca>
>> wrote:
>> This is not actually so. There’s nothing special about the postgres
>> database, drop it and see. The system information lives in system catalogs
>> that are not attached to any particular database. The template0 and
>> template1 databases are “special” in that new databases are created by
>> copying the contents of those templates, so alterations to them will
>> percolate into any new databases created, so they should generally be left
>> alone (unless you have a reason to want something included in all new
>> databases). If you drop template1 you will find it hard to create new
>> databases (unless you specify a different template) but otherwise things
>> will keep running.
>> Anyways, I imagine the mystery of the Esri connection to ‘postgres’ is
>> just that someone at Esri thought the same as you, seeing that most builds
>> of postgres do ship with a postgres database already created, so that the
>> postgres database user can easily have something to connect to that is not
>> one of the templates. But it’s not special, it’s just a database.
>> P.
>> On Aug 21, 2019, at 9:33 AM, Andy Anderson <aanderson at amherst.edu> wrote:
>> The postgres database is set up by default by the postgres server and
>> holds configuration information: databases, users, etc. Don’t touch. Set up
>> another database for Arc to use.
>> — Andy
>> On Aug 21, 2019, at 12:23 PM, Basques, Bob (CI-StPaul) <
>> That’s what I’m talking about.  when I first tried to connect to Posters
>> (and the “postgres” named database, I kept getting an error from ArcGIS
>> saying the the “postgres” name for a database was a bad thing, and it
>> wouldn’t connect.  After much searching, I discover that the name,
>> “postgres” for a database wasn’t allowed by the ArcGIS client to connect
>> to.
>> As long as you don’t try connecting to the default “postgres” database,
>> all seem to work fine.
>> bobb
>> On Aug 21, 2019, at 10:59 AM, Shaozhong SHI <shishaozhong at gmail.com>
>> organization.
>> Hi, Bobb,
>> I am confused with this.
>> The idea is to use ArcGIS desktops to read data from PostGIS/PostgreSQL.
>> How best to configure and make them happy to talk to each other?
>> Regards,
>> Shao
>> On Wed, 21 Aug 2019 at 15:01, Basques, Bob (CI-StPaul) <
>>> Shao,
>>> I had to dig fairly deeply into the ESRI site to find this particular
>>> explanation for why the service couldn’t/wouldn’t get connected.  Just to
>>> be clear, we do use logins for accessing the database, we just have chosen
>>> to use the “postgres” (named) database.
>>> So, I just went and tried to find the refence I found previously, and
>>> can’t find it (real quick).  Anyway,as long as you don’t try to connect to
>>> the “postgres” database, things do seem to work ok.
>>> bobb
>>> On Aug 21, 2019, at 2:18 AM, Shaozhong SHI <shishaozhong at gmail.com>
>>> organization.
>>> Hi, Bob,
>>> Can you point me to excellent technical documentation on what you
>>> mentioned, so that I can double-check.
>>> My colleagues have made it working, but there are some issues.  For
>>> instance, not all ArcGIS desktops can access and retrieve data.
>>> Looking forward to have more insight into this matter.
>>> Regards,
>>> Shao
>>> On Tue, 20 Aug 2019 at 17:08, Basques, Bob (CI-StPaul) <
>>>> All,
>>>> One biggie, is that the ESRI side does not like connecting to the
>>>> “postgres” named database, claiming it’s a System database (whatever that
>>>> means).  This is not readily available as a limitation either when looking
>>>> for reasons why it won’t connect.  We’ve been using the “postgres” database
>>>> name for years (a decade now??) with no ill effects from other
>>>> applications/ connections.  I sort of understand this from the commercial
>>>> side having worked with other databases like Oracle and MSSQL, but still,
>>>> there should be a way to side step this with a setting somewhere.
>>>> I looked high and low for a way to alias the “postgres” database name
>>>> inside of Postgres, but didn’t find anything very easy to implement or
>>>> maintain very easily.  I did think about setting up another dataabase and
>>>> using Views to the postgres database, but that seemed like a bad idea for
>>>> some reason, along with being somewhat hard to maintain, but upon
>>>> reflection I keep coming back to the idea.
>>>> All non “postgres” named connections seem to work fine so far.  Haven’t
>>>> implemented anything yet that is really heavy duty as far as loading
>>>> though, so who knows.
>>>> Anyway, just my 2cents.
>>>> bobb
>>>> On Aug 20, 2019, at 10:12 AM, Shaozhong SHI <shishaozhong at gmail.com>
>>>> organization.
>>>> How to ensure that all versions of ArcGIS desktop applications can
>>>> access and read from server-based PostGIS/PostgreSQL?
>>>> Regards,
>>>> Shao
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190823/e8c909fc/attachment.html>
