[postgis-users] ArcGIS desktop accessing and reading from PostGIS
Shaozhong SHI shishaozhong at gmail.com
Fri Aug 23 09:05:23 PDT 2019
Hi, Bobb,
Fundamentally, PostGIS/PostgresSQL can be used to create a database.  When
one creates a table, the table is defined.  Namely, a schema is created and
defined.
Am I right?
Can we define a schema so that all other applications including ArcGIS,
MapInfo and QGIS can read?
Regards,
Shao
On Fri, 23 Aug 2019 at 14:29, Basques, Bob (CI-StPaul) <
bob.basques at ci.stpaul.mn.us> wrote:
> Correct.  One or more tables can be defined in a schema.
> On Aug 23, 2019, at 3:36 AM, Shaozhong SHI <shishaozhong at gmail.com> wrote:
> *Think Before You Click: *This email originated *outside *our
> organization.
> Hi, Bobb,
> A database has many schemas.
> A schema is a definition of a data structure.  Many tables can be created
> by using this data structure.
> Am I right?
> Regards,
> Shao
> On Thu, 22 Aug 2019 at 17:25, Basques, Bob (CI-StPaul) <
>> Shao,
>> I’ve always thought of a schema as a sub-grouping inside of a database,
>> as in a database can contain many schemas.
>> Or, from a higher point of view . . .
>> Database instances (Postgres, Oracle, MySQL, etc) contain one or more
>> databases, and each database can contain one or more schemas . . .
>> bobb
>> On Aug 22, 2019, at 11:07 AM, Shaozhong SHI <shishaozhong at gmail.com>
>> organization.
>> Hi, Bobb,
>> Thanks.
>> A lot of technical terms used are interchangeable.
>> Am I right to say this? When a postgreSQL database is created, a data
>> structure is created.  This data structure is referred to as a scheme?
>> Namely, in this instance, a scheme = a data structure created with
>> postgreSQL executables.
>> Am I right?
>> Regards,
>> Shao
>> On Thu, 22 Aug 2019 at 16:37, Andy Anderson <aanderson at amherst.edu>
>> wrote:
>>> Thanks for the correction, Paul, I guess I’ve been relying on my MySQL
>>> experience, which stores user data in the "mysql" database.
>>> — Andy
>>> On Aug 21, 2019, at 12:59 PM, Paul Ramsey <pramsey at cleverelephant.ca>
>>> wrote:
>>> This is not actually so. There’s nothing special about the postgres
>>> database, drop it and see. The system information lives in system catalogs
>>> that are not attached to any particular database. The template0 and
>>> template1 databases are “special” in that new databases are created by
>>> copying the contents of those templates, so alterations to them will
>>> percolate into any new databases created, so they should generally be left
>>> alone (unless you have a reason to want something included in all new
>>> databases). If you drop template1 you will find it hard to create new
>>> databases (unless you specify a different template) but otherwise things
>>> will keep running.
>>> Anyways, I imagine the mystery of the Esri connection to ‘postgres’ is
>>> just that someone at Esri thought the same as you, seeing that most builds
>>> of postgres do ship with a postgres database already created, so that the
>>> postgres database user can easily have something to connect to that is not
>>> one of the templates. But it’s not special, it’s just a database.
>>> P.
>>> On Aug 21, 2019, at 9:33 AM, Andy Anderson <aanderson at amherst.edu>
>>> wrote:
>>> The postgres database is set up by default by the postgres server and
>>> holds configuration information: databases, users, etc. Don’t touch. Set up
>>> another database for Arc to use.
>>> — Andy
>>> On Aug 21, 2019, at 12:23 PM, Basques, Bob (CI-StPaul) <
>>> That’s what I’m talking about.  when I first tried to connect to Posters
>>> (and the “postgres” named database, I kept getting an error from ArcGIS
>>> saying the the “postgres” name for a database was a bad thing, and it
>>> wouldn’t connect.  After much searching, I discover that the name,
>>> “postgres” for a database wasn’t allowed by the ArcGIS client to connect
>>> to.
>>> As long as you don’t try connecting to the default “postgres” database,
>>> all seem to work fine.
>>> bobb
>>> On Aug 21, 2019, at 10:59 AM, Shaozhong SHI <shishaozhong at gmail.com>
>>> organization.
>>> Hi, Bobb,
>>> I am confused with this.
>>> The idea is to use ArcGIS desktops to read data from PostGIS/PostgreSQL.
>>> How best to configure and make them happy to talk to each other?
>>> Regards,
>>> Shao
>>> On Wed, 21 Aug 2019 at 15:01, Basques, Bob (CI-StPaul) <
>>>> Shao,
>>>> I had to dig fairly deeply into the ESRI site to find this particular
>>>> explanation for why the service couldn’t/wouldn’t get connected.  Just to
>>>> be clear, we do use logins for accessing the database, we just have chosen
>>>> to use the “postgres” (named) database.
>>>> So, I just went and tried to find the refence I found previously, and
>>>> can’t find it (real quick).  Anyway,as long as you don’t try to connect to
>>>> the “postgres” database, things do seem to work ok.
>>>> bobb
>>>> On Aug 21, 2019, at 2:18 AM, Shaozhong SHI <shishaozhong at gmail.com>
>>>> organization.
>>>> Hi, Bob,
>>>> Can you point me to excellent technical documentation on what you
>>>> mentioned, so that I can double-check.
>>>> My colleagues have made it working, but there are some issues.  For
>>>> instance, not all ArcGIS desktops can access and retrieve data.
>>>> Looking forward to have more insight into this matter.
>>>> Regards,
>>>> Shao
>>>> On Tue, 20 Aug 2019 at 17:08, Basques, Bob (CI-StPaul) <
>>>>> All,
>>>>> One biggie, is that the ESRI side does not like connecting to the
>>>>> “postgres” named database, claiming it’s a System database (whatever that
>>>>> means).  This is not readily available as a limitation either when looking
>>>>> for reasons why it won’t connect.  We’ve been using the “postgres” database
>>>>> name for years (a decade now??) with no ill effects from other
>>>>> applications/ connections.  I sort of understand this from the commercial
>>>>> side having worked with other databases like Oracle and MSSQL, but still,
>>>>> there should be a way to side step this with a setting somewhere.
>>>>> I looked high and low for a way to alias the “postgres” database name
>>>>> inside of Postgres, but didn’t find anything very easy to implement or
>>>>> maintain very easily.  I did think about setting up another dataabase and
>>>>> using Views to the postgres database, but that seemed like a bad idea for
>>>>> some reason, along with being somewhat hard to maintain, but upon
>>>>> reflection I keep coming back to the idea.
>>>>> All non “postgres” named connections seem to work fine so far.
>>>>> Haven’t implemented anything yet that is really heavy duty as far as
>>>>> loading though, so who knows.
>>>>> Anyway, just my 2cents.
>>>>> bobb
>>>>> On Aug 20, 2019, at 10:12 AM, Shaozhong SHI <shishaozhong at gmail.com>
>>>>> organization.
>>>>> How to ensure that all versions of ArcGIS desktop applications can
>>>>> access and read from server-based PostGIS/PostgreSQL?
>>>>> Regards,
>>>>> Shao
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190823/80bf9a1d/attachment.html>
