[postgis-users] ArcGIS desktop accessing and reading from PostGIS
Shaozhong SHI
shishaozhong at gmail.com
Mon Aug 26 09:40:26 PDT 2019
Hi, Andy,
How can a schema set and used properly, so that ArcGIS, MapInfo and QGIS
can read and understand geographical data properly?
Regards,
Shao
On Mon, 26 Aug 2019 at 16:47, Andy Anderson <aanderson at amherst.edu> wrote:
> Postgres Book says:
> 1) A database *cluster* is a collection of databases.
> 2) A *database *can have many schemas.
> 3) A *schema *is a collection of tables, indices, functions, data types,
> and operators. Essentially it is a name space that can be used to
> compartmentalize particular purposes that might have duplicate names, a
> development version and a production version (e.g. develop.mapit and
> product.mapit). If you only have one schema you don’t need to refer to it;
> if you have more than one there is a lookup order if the schema is not
> referenced.
> — Andy
> On Aug 23, 2019, at 12:05 PM, Shaozhong SHI <shishaozhong at gmail.com>
> wrote:
> Hi, Bobb,
> Fundamentally, PostGIS/PostgresSQL can be used to create a database. When
> one creates a table, the table is defined. Namely, a schema is created and
> defined.
> Am I right?
> Can we define a schema so that all other applications including ArcGIS,
> MapInfo and QGIS can read?
> Regards,
> Shao
> On Fri, 23 Aug 2019 at 14:29, Basques, Bob (CI-StPaul) <
> bob.basques at ci.stpaul.mn.us> wrote:
>> Correct. One or more tables can be defined in a schema.
>> On Aug 23, 2019, at 3:36 AM, Shaozhong SHI <shishaozhong at gmail.com>
>> wrote:
>> *Think Before You Click: *This email originated *outside *our
>> organization.
>> Hi, Bobb,
>> A database has many schemas.
>> A schema is a definition of a data structure. Many tables can be created
>> by using this data structure.
>> Am I right?
>> Regards,
>> Shao
>> On Thu, 22 Aug 2019 at 17:25, Basques, Bob (CI-StPaul) <
>>> Shao,
>>> I’ve always thought of a schema as a sub-grouping inside of a database,
>>> as in a database can contain many schemas.
>>> Or, from a higher point of view . . .
>>> Database instances (Postgres, Oracle, MySQL, etc) contain one or more
>>> databases, and each database can contain one or more schemas . . .
>>> bobb
>>> On Aug 22, 2019, at 11:07 AM, Shaozhong SHI <shishaozhong at gmail.com>
>>> organization.
>>> Hi, Bobb,
>>> Thanks.
>>> A lot of technical terms used are interchangeable.
>>> Am I right to say this? When a postgreSQL database is created, a data
>>> structure is created. This data structure is referred to as a scheme?
>>> Namely, in this instance, a scheme = a data structure created with
>>> postgreSQL executables.
>>> Am I right?
>>> Regards,
>>> Shao
>>> On Thu, 22 Aug 2019 at 16:37, Andy Anderson <aanderson at amherst.edu>
>>> wrote:
>>>> Thanks for the correction, Paul, I guess I’ve been relying on my MySQL
>>>> experience, which stores user data in the "mysql" database.
>>>> — Andy
>>>> On Aug 21, 2019, at 12:59 PM, Paul Ramsey <pramsey at cleverelephant.ca>
>>>> wrote:
>>>> This is not actually so. There’s nothing special about the postgres
>>>> database, drop it and see. The system information lives in system catalogs
>>>> that are not attached to any particular database. The template0 and
>>>> template1 databases are “special” in that new databases are created by
>>>> copying the contents of those templates, so alterations to them will
>>>> percolate into any new databases created, so they should generally be left
>>>> alone (unless you have a reason to want something included in all new
>>>> databases). If you drop template1 you will find it hard to create new
>>>> databases (unless you specify a different template) but otherwise things
>>>> will keep running.
>>>> Anyways, I imagine the mystery of the Esri connection to ‘postgres’ is
>>>> just that someone at Esri thought the same as you, seeing that most builds
>>>> of postgres do ship with a postgres database already created, so that the
>>>> postgres database user can easily have something to connect to that is not
>>>> one of the templates. But it’s not special, it’s just a database.
>>>> P.
>>>> On Aug 21, 2019, at 9:33 AM, Andy Anderson <aanderson at amherst.edu>
>>>> wrote:
>>>> The postgres database is set up by default by the postgres server and
>>>> holds configuration information: databases, users, etc. Don’t touch. Set up
>>>> another database for Arc to use.
>>>> — Andy
>>>> On Aug 21, 2019, at 12:23 PM, Basques, Bob (CI-StPaul) <
>>>> That’s what I’m talking about. when I first tried to connect to
>>>> Posters (and the “postgres” named database, I kept getting an error from
>>>> ArcGIS saying the the “postgres” name for a database was a bad thing, and
>>>> it wouldn’t connect. After much searching, I discover that the name,
>>>> “postgres” for a database wasn’t allowed by the ArcGIS client to connect
>>>> to.
>>>> As long as you don’t try connecting to the default “postgres” database,
>>>> all seem to work fine.
>>>> bobb
>>>> On Aug 21, 2019, at 10:59 AM, Shaozhong SHI <shishaozhong at gmail.com>
>>>> organization.
>>>> Hi, Bobb,
>>>> I am confused with this.
>>>> The idea is to use ArcGIS desktops to read data from PostGIS/PostgreSQL.
>>>> How best to configure and make them happy to talk to each other?
>>>> Regards,
>>>> Shao
>>>> On Wed, 21 Aug 2019 at 15:01, Basques, Bob (CI-StPaul) <
>>>>> Shao,
>>>>> I had to dig fairly deeply into the ESRI site to find this particular
>>>>> explanation for why the service couldn’t/wouldn’t get connected. Just to
>>>>> be clear, we do use logins for accessing the database, we just have chosen
>>>>> to use the “postgres” (named) database.
>>>>> So, I just went and tried to find the refence I found previously, and
>>>>> can’t find it (real quick). Anyway,as long as you don’t try to connect to
>>>>> the “postgres” database, things do seem to work ok.
>>>>> bobb
>>>>> On Aug 21, 2019, at 2:18 AM, Shaozhong SHI <shishaozhong at gmail.com>
>>>>> organization.
>>>>> Hi, Bob,
>>>>> Can you point me to excellent technical documentation on what you
>>>>> mentioned, so that I can double-check.
>>>>> My colleagues have made it working, but there are some issues. For
>>>>> instance, not all ArcGIS desktops can access and retrieve data.
>>>>> Looking forward to have more insight into this matter.
>>>>> Regards,
>>>>> Shao
>>>>> On Tue, 20 Aug 2019 at 17:08, Basques, Bob (CI-StPaul) <
>>>>>> All,
>>>>>> One biggie, is that the ESRI side does not like connecting to the
>>>>>> “postgres” named database, claiming it’s a System database (whatever that
>>>>>> means). This is not readily available as a limitation either when looking
>>>>>> for reasons why it won’t connect. We’ve been using the “postgres” database
>>>>>> name for years (a decade now??) with no ill effects from other
>>>>>> applications/ connections. I sort of understand this from the commercial
>>>>>> side having worked with other databases like Oracle and MSSQL, but still,
>>>>>> there should be a way to side step this with a setting somewhere.
>>>>>> I looked high and low for a way to alias the “postgres” database name
>>>>>> inside of Postgres, but didn’t find anything very easy to implement or
>>>>>> maintain very easily. I did think about setting up another dataabase and
>>>>>> using Views to the postgres database, but that seemed like a bad idea for
>>>>>> some reason, along with being somewhat hard to maintain, but upon
>>>>>> reflection I keep coming back to the idea.
>>>>>> All non “postgres” named connections seem to work fine so far.
>>>>>> Haven’t implemented anything yet that is really heavy duty as far as
>>>>>> loading though, so who knows.
>>>>>> Anyway, just my 2cents.
>>>>>> bobb
>>>>>> On Aug 20, 2019, at 10:12 AM, Shaozhong SHI <shishaozhong at gmail.com>
>>>>>> organization.
>>>>>> How to ensure that all versions of ArcGIS desktop applications can
>>>>>> access and read from server-based PostGIS/PostgreSQL?
>>>>>> Regards,
>>>>>> Shao
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> postgis-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190826/40529b11/attachment.html>
