[postgis-users] ArcGIS desktop accessing and reading from PostGIS
Bruce Rindahl
bruce.rindahl at gmail.com
Mon Aug 26 10:34:52 PDT 2019
I am not sure if this thread needs to be all this complicated. ArcMap can
read PostgreSQL/PostGIS directly without any configuration issues. From
the ArcMap interface, select File -> Add Data -> Add Query Layer. From
this menu you create a connection to a database on your server with your
user name and password. You can create as many connections as you want and
save them. Then pick the table you want. It even reads the SRS from
PostGIS. Details are at:
https://desktop.arcgis.com/en/arcmap/latest/map/working-with-layers/creating-a-query-layer.htm
You can save the layer as a *.lyr file with all the connection info for
others to use.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190826/cc2206b9/attachment.html>
