[postgis-users] breake lines
Simon Norris
snorris at hillcrestgeo.ca
Fri Aug 30 09:13:59 PDT 2019
You probably want ST_Split().
If you are working with your previous example, one way to avoid precision problems after applying the split might be to use the linear referencing funtions to shrink the lines by your preferred tolerance.
In case you haven't already seen it, this illustrates the numerical precision difficulty:
https://observablehq.com/@mourner/non-robust-arithmetic-as-art
> On Aug 30, 2019, at 1:51 AM, paul.malm at lfv.se wrote:
> Hi,
> What PostGIS command do I use to breake linestrings or multilinestrings using another “breaking” table including linestrings or multilinestrings, without erasing any points or adding anything from the “braking” layer?
> Thanks in advance,
> Paul
> postgis-users mailing list
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/postgis-users <https://lists.osgeo.org/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190830/e6a7d9bf/attachment.html>
