[postgis-users] Is there a MapInfo to PostGIS/PostgreSQL loader?
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Sat Aug 31 09:53:54 PDT 2019
Shao -
If you want to visualize spatial data in a Postgres/PostGIS database
using MapInfo as the viewing program you have to:
* Create a schema / table in : *MAPINFO.MAPINFO_MAPCATALOG. *
* Populate it with information about your spatial tables in the
Postgres database. It contains approximately the same information
that's stored in the normal *public.geometry_columns* view plus some
extra MapInfo specific information.
MapInfo uses this table to get information about the different spatial
tables in the database, so it has to be present and populated with the
correct information.
If you use OGR2OGR to upload spatial data to Postgres, OGR2OGR
*won't***create or populate the *MAPINFO.MAPINFO_MAPCATALOG* meta-table
for you. However, the Easyloader upload program is capable of that.
Finally, you can create and populate the *MAPINFO.MAPINFO_MAPCATALOG*
table manually.
You can download the Easyloader program from the Pitney Bowes MapInfo
Web site (Free download)
I suggest you read (and understand) the following article from the
MapInfo knowledge base:
http://support.pitneybowes.com/VFP05_KnowledgeWithSidebarHowTo?id=kA180000000PNiiCAG
Med venlig hilsen / Kind regards
Bo Victor Thomsen
aestasGIS Denmark
Den 31-08-2019 kl. 17:41 skrev Shaozhong SHI:
> Hi, Jeff,
> Thanks. We can upload and visualise in qgis.
> But, I wonder where upload can include metadata.
> If you use qgis, you can use the data, but when you click on
> properties, you cannot find metadata.
> How to upload metadata into postgis/postgresql?
> Regards,
> Shao
> On Friday, 30 August 2019, Jeff Norville <jeff at jnorville.com
> <mailto:jeff at jnorville.com>> wrote:
> Hi Shao,
> I generally use QGIS to visualize postgis / postgresql loads - but
> mostly because it's free. But if you're using MapInfo it seems the
> EasyLoader may be the way forward - there are some posts about
> this over on gis.stackexchange.com <http://gis.stackexchange.com>,
> including this guide:
> https://www.slideshare.net/peterhorsbollmoller/mapinfo-professional-120-and-sql-server-2008
> <https://www.slideshare.net/peterhorsbollmoller/mapinfo-professional-120-and-sql-server-2008>
> Best,
> Jeff
> On Tue, Aug 27, 2019 at 9:03 PM Shaozhong SHI
> <shishaozhong at gmail.com <mailto:shishaozhong at gmail.com>> wrote:
> Hi, Tonis,
> We will bear that in mind.
> A friend of mine says that the problem is not being able to
> visualize what got into postgre.
> Regards,
> Shao
> On Tuesday, 27 August 2019, Tõnis Kärdi <tonis.kardi at gmail.com
> <mailto:tonis.kardi at gmail.com>> wrote:
> Hi,
> one option would be to use ogr2ogr. And I can't remember
> exactly but I think MapInfo's EasyLoader could do that
> very fine aswell.
> All the best,
> Tõnis
> On 27.08.19 15:44, Paolo Cavallini wrote:
> Not that I know of, but you can use ogr or QGIS for this.
> Cheers.
> On 27 August 2019 15:14:06 EEST, Shaozhong SHI
> Hi,
> For instance, use
> psql.exe or something like that?
> Regards,
> Shao
> Sorry for being short
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> <mailto:postgis-users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/postgis-users
> <https://lists.osgeo.org/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190831/86d1c197/attachment.html>
