[postgis-users] PostgreSQL 12 and PostGIS
Bo Guo
bo.guo at gisticinc.com
Sun Dec 22 18:15:52 PST 2019
Regina and Stefan,
I might have run into a similar issues today as I was trying to upgrade
PostgreSQL 11 w/ PostGIS 2.5 to PostgreSQL 12 w/ PostGIS 3.0.
The pg_upgradecluster command (sudo pg_upgradecluster -m upgrade 11
main) failed its check for the following required libraries:
could not load library "$libdir/postgis-2.5": ERROR: could not
access file "$libdir/postgis-2.5": No such file or directory
could not load library "$libdir/rtpostgis-2.5": ERROR: could not
access file "$libdir/rtpostgis-2.5": No such file or directory
could not load library "$libdir/postgis_topology-2.5": ERROR:
could not access file "$libdir/postgis_topology-2.5": No such file or
directory
I have postgis-2.5 in the /usr/share/postgresql/11/contrib/ folder AND
/usr/share/postgresql/12/contrib/ folder. I also have postgis-3.0 under
/usr/share/postgresql/12/contrib/.
Thanks for your help!
Bo
Gistic Research, Inc.
On 10/4/19 8:16 AM, Regina Obe wrote:
> Stefan,
> Which distro do you get your PostgreSQL 12 from. I’m assuming
> apt.postgresql.org
> If so you should report on their mailing list, as that would be a
> packaging bug,not a PostGIS one and no one on the PostGIS project is
> on the apt team.
> https://www.postgresql.org/list/pgsql-pkg-debian/
> Thanks,
> Regina
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
> *On Behalf Of *Stefan Wolf
> *Sent:* Friday, October 4, 2019 6:19 AM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* [postgis-users] PostgreSQL 12 and PostGIS
> Today I’ve installed the brand new PostgreSQL 12 on Ubuntu 18.04
> “apt-get install postgis” will install PostGIS 2.5.2, but the PATH
> is wrong: /usr/share/postgresql/11/…
> So CREATE EXTENSION postgis will fail.
> Greetings from Berlin
> -Stefan Wolf-
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191222/46d4069a/attachment.html>
