[postgis-users] Problems with installing postgis in windows
Regina Obe lr at pcorp.us
Thu Feb 28 05:28:21 PST 2019
I'm thinking about how many people get bitten by this.
Would it help if I put –edb or something like that in the installer name?
The binaries should work fine with BigSQL though aside from the paths, but I
figured most people using BigSQL would be using the BigSQL postgis binaries
so no need to create a batch script for it or anything aside from a cursory
explanation.
Thanks,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of paul.malm at lfv.se
Sent: Thursday, February 28, 2019 3:25 AM
To: postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] Problems with installing postgis in windows
Sorry it works now, I had used postgres “BIGSQL”, not  EDB installation!
Från: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] För Malm,
Paul (Operations AIM)
Skickat: den 27 februari 2019 11:03
Till: postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
Ämne: [postgis-users] Problems with installing postgis in windows
I’ve tried to install Postgis for windows
(postgis-bundle-pg11x64-setup-2.5.1-1.exe) with PostgreSQL11.
But I receive this message at the end of the installation:
ERROR:  could not open extension control file
"C:/POSTGR~1/pg11/../pg11/share/postgresql/extension/postgis.control": No
such file or directory
Then I down loaded the zip file and copied the postgis.control to this
directory and tried to install again.
This time I got this error message instead at the end of the installation:
ERROR:  extension "postgis" has no installation script nor update path for
version "2.5.1"
Has anyone any idea what I’m doing wrong?
Kind regards,
Paul
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190228/b0132609/attachment.html>
