[postgis-users] Slow construction of GiST index, but better with smaller # of big rows
Paul Norman penorman at mac.com
Tue Jan 15 14:07:15 PST 2019
On 2019-01-15 1:45 p.m., Felix Kunde wrote:
> For optimal performance your spatial can be clustered on disk. For
> this, I created a functional btree index transforming the geometries
> with ST_GeoHash. Btree indexes can be created in parallel with the
> latest Postgres version (took me 30min). Unfortunately, the CLUSTER
> command then takes a long time (8hrs on my machine).
If you're loading up the data a method faster than CLUSTER is to create
a new table with CREATE TABLE foo AS SELECT * FROM foo_tmp ORDER BY
ST_GeoHash(ST_Transform(ST_Envelope(way),4326),10) COLLATE "C"
With CLUSTER you have to create a temporary index, rewrite the table,
and then recreate that temporary index, only to drop it again.
