[postgis-users] select statement returns different results when fired manually or by update trigger
Marcin Mionskowski
mionskowskimarcin at gmail.com
Fri Mar 15 12:59:03 PDT 2019
I'm not sure I understood you correctly, but it looks like it works on my
postgres-postgis installation. See the attached file.
"PostgreSQL 11.2 (Ubuntu 11.2-1.pgdg18.04+1) on x86_64-pc-linux-gnu,
compiled by gcc (Ubuntu 7.3.0-27ubuntu1~18.04) 7.3.0, 64-bit"
"POSTGIS="2.5.1 r17027" [EXTENSION] PGSQL="110" GEOS="3.6.2-CAPI-1.10.2
4d2925d6" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.3, released
2017/11/20" LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.2.1" RASTER"
pt., 15 mar 2019 o 16:30 <Michael.Haertel at t-systems.com> napisał(a):
> Hello List,
> I observed a strange behavior when I implemented a trigger function.
> Given: Table “fcp_4258_kls_addr” with address points, Table
> “fcp_4258_candidates” with some other points.
> Objective: find closest point in fcp_4258_kls_addr to a point in
> fcp_4258_candidates (from all found address points in a radius of 0.01
> degrees around the candidate).
> After playing around with the statements I came up with this:
> select s.id, ST_DistanceSphere(ST_SetSRID(ST_Point(6.951468,
> 50.93651),4258), s.wkb_geometry) as klsdistancetocandidatem FROM
> kddb.fcp_4258_kls_addr s WHERE ST_DWithin(s.wkb_geometry,
> ST_SetSRID(ST_Point(6.951468, 50.93651),4258), 0.01) ORDER BY
> klsdistancetocandidatem ASC LIMIT 1;
> I hope that the function does what I want: First select all addresses
> within 0.01 degrees distance to the point 6.951468, 50.93651 and then
> calculate the distance to all of them. Order by distance in ascending order
> and select the first which should be the closest to the questioned
> candidate.
> This works fine when I run the statement manually in the console:
> id | geo_kls_dist2candidate_m
> 17553866 | 6.85436569
> My goal was to save the closest address point (id) and the distance to the
> table as soon as the candidate table is updated. The relevant line in the
> trigger function for the trigger “BEFORE UPDATE ON candidates FOR EACH ROW
> EXECUTE PROCEDURE” looks like this:
> SELECT s.id, ST_DistanceSphere(s.wkb_geometry, NEW.wkb_geometry) INTO
> klsid, klsdistancetocandidatem FROM kddb.fcp_4258_kls_addr s WHERE
> ST_DWithin(s.wkb_geometry, NEW.wkb_geometry, 0.01) ORDER BY
> NEW.geo_kls_id = klsid;
> NEW.geo_kls_distance2candidate_m = klsdistancetocandidatem;
> I assumed that the trigger does the same as the select statement but I get
> a different result for a candidate. The address point referenced in the
> candidates table for the candidate with the coordinates 6.951468, 50.93651
> is 497 meters away and not 6.8 meters.
> Some findings:
> - The id returned is within 0.01 degree radius for the candidate
> - The address point with the given id has correctly referenced
> distance to the candidate (but is not the closest)
> - The address point returned does neither belong to the preceding
> candidate point nor to the successive candidate (when sorted by primary key)
> - The update trigger is fired and the procedure is executed (Tested
> with various update statements)
> The wkb_geometry doesn’t change with the update. I have no idea why the
> address points are different.
> Can anybody help?
> Michael
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190315/bd7c35d4/attachment.html>
Type: application/sql
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190315/bd7c35d4/attachment.bin>
