[postgis-users] Segfault when calling ST_AsGeoJSON()
Micha Silver tsvibar at gmail.com
Thu Mar 21 05:45:50 PDT 2019
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190321/e8903cce/attachment.html>
< 2019-03-21 13:11:25.560 IST geodba on geodata >DEBUG:  StartTransactionCommand
< 2019-03-21 13:11:25.560 IST geodba on geodata >STATEMENT:  SELECT ST_AsGeoJSON('POINT(35 30)');
< 2019-03-21 13:11:25.560 IST geodba on geodata >DEBUG:  name: unnamed; blockState:       DEFAULT; state: INPROGR, xid/subid/cid: 0/1/0, nestlvl: 1, children:
< 2019-03-21 13:11:25.560 IST  on  >DEBUG:  writing stats file "pg_stat_tmp/db_13056.stat"
< 2019-03-21 13:11:25.560 IST  on  >DEBUG:  writing stats file "pg_stat_tmp/db_0.stat"
< 2019-03-21 13:11:25.570 IST  on  >DEBUG:  StartTransaction
< 2019-03-21 13:11:25.570 IST  on  >DEBUG:  name: unnamed; blockState:       DEFAULT; state: INPROGR, xid/subid/cid: 0/1/0, nestlvl: 1, children:
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  pg_authid: vac: 0 (threshold 50), anl: 0 (threshold 50)
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  pg_attribute: vac: 0 (threshold 512), anl: 0 (threshold 281)
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  pg_index: vac: 0 (threshold 73), anl: 0 (threshold 61)
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  pg_opclass: vac: 0 (threshold 76), anl: 0 (threshold 63)
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  pg_am: vac: 0 (threshold 51), anl: 0 (threshold 50)
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  pg_amproc: vac: 0 (threshold 119), anl: 0 (threshold 84)
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  pg_database: vac: 0 (threshold 50), anl: 0 (threshold 50)
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  pg_db_role_setting: vac: 0 (threshold 50), anl: 0 (threshold 50)
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  pg_tablespace: vac: 0 (threshold 50), anl: 0 (threshold 50)
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  pg_pltemplate: vac: 0 (threshold 52), anl: 0 (threshold 51)
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  pg_auth_members: vac: 0 (threshold 50), anl: 0 (threshold 50)
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  pg_shdepend: vac: 149 (threshold 737), anl: 0 (threshold 394)
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  pg_shdescription: vac: 0 (threshold 50), anl: 0 (threshold 50)
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  pg_shseclabel: vac: 0 (threshold 50), anl: 0 (threshold 50)
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  pg_class: vac: 0 (threshold 109), anl: 0 (threshold 80)
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  CommitTransaction
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  name: unnamed; blockState:       STARTED; state: INPROGR, xid/subid/cid: 0/1/0, nestlvl: 1, children:
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  shmem_exit(0): 1 before_shmem_exit callbacks to make
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  shmem_exit(0): 7 on_shmem_exit callbacks to make
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  proc_exit(0): 2 callbacks to make
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  exit(0)
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  shmem_exit(-1): 0 before_shmem_exit callbacks to make
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  shmem_exit(-1): 0 on_shmem_exit callbacks to make
< 2019-03-21 13:11:25.571 IST  on  >DEBUG:  proc_exit(-1): 0 callbacks to make
< 2019-03-21 13:11:25.572 IST  on  >DEBUG:  server process (PID 4551) exited with exit code 0
< 2019-03-21 13:11:25.910 IST  on  >DEBUG:  server process (PID 4547) was terminated by signal 11: Segmentation fault
< 2019-03-21 13:11:25.910 IST  on  >DETAIL:  Failed process was running: SELECT ST_AsGeoJSON('POINT(35 30)');
< 2019-03-21 13:11:25.910 IST  on  >LOG:  server process (PID 4547) was terminated by signal 11: Segmentation fault
< 2019-03-21 13:11:25.911 IST  on  >LOG:  terminating any other active server processes
< 2019-03-21 13:11:25.911 IST  on  >DEBUG:  sending SIGQUIT to process 4090
< 2019-03-21 13:11:25.911 IST  on  >DEBUG:  sending SIGQUIT to process 4089
< 2019-03-21 13:11:25.911 IST  on  >DEBUG:  sending SIGQUIT to process 4091
< 2019-03-21 13:11:25.911 IST  on  >DEBUG:  sending SIGQUIT to process 4092
< 2019-03-21 13:11:25.911 IST  on  >DEBUG:  sending SIGQUIT to process 4093
< 2019-03-21 13:11:25.911 IST  on  >WARNING:  terminating connection because of crash of another server process
< 2019-03-21 13:11:25.911 IST  on  >DETAIL:  The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
< 2019-03-21 13:11:25.911 IST  on  >HINT:  In a moment you should be able to reconnect to the database and repeat your command.
< 2019-03-21 13:11:25.911 IST  on  >DEBUG:  writing stats file "pg_stat/global.stat"
< 2019-03-21 13:11:25.911 IST  on  >DEBUG:  writing stats file "pg_stat/db_19293.stat"
< 2019-03-21 13:11:25.911 IST  on  >DEBUG:  forked new backend, pid=4554 socket=11
< 2019-03-21 13:11:25.911 IST  on  >DEBUG:  removing temporary stats file "pg_stat_tmp/db_19293.stat"
< 2019-03-21 13:11:25.911 IST  on  >DEBUG:  writing stats file "pg_stat/db_17690.stat"
< 2019-03-21 13:11:25.912 IST [unknown] on [unknown] >LOG:  connection received: host=127.0.0.1 port=39454
< 2019-03-21 13:11:25.912 IST  on  >DEBUG:  removing temporary stats file "pg_stat_tmp/db_17690.stat"
< 2019-03-21 13:11:25.912 IST  on  >DEBUG:  writing stats file "pg_stat/db_13056.stat"
< 2019-03-21 13:11:25.912 IST geodba on geodata >FATAL:  the database system is in recovery mode
< 2019-03-21 13:11:25.912 IST geodba on geodata >DEBUG:  shmem_exit(1): 0 before_shmem_exit callbacks to make
< 2019-03-21 13:11:25.912 IST geodba on geodata >DEBUG:  shmem_exit(1): 0 on_shmem_exit callbacks to make
< 2019-03-21 13:11:25.912 IST geodba on geodata >DEBUG:  proc_exit(1): 1 callbacks to make
< 2019-03-21 13:11:25.912 IST geodba on geodata >DEBUG:  exit(1)
< 2019-03-21 13:11:25.912 IST geodba on geodata >DEBUG:  shmem_exit(-1): 0 before_shmem_exit callbacks to make
< 2019-03-21 13:11:25.912 IST geodba on geodata >DEBUG:  shmem_exit(-1): 0 on_shmem_exit callbacks to make
< 2019-03-21 13:11:25.912 IST  on  >DEBUG:  removing temporary stats file "pg_stat_tmp/db_13056.stat"
< 2019-03-21 13:11:25.912 IST geodba on geodata >DEBUG:  proc_exit(-1): 0 callbacks to make
< 2019-03-21 13:11:25.912 IST  on  >DEBUG:  writing stats file "pg_stat/db_0.stat"
< 2019-03-21 13:11:25.913 IST  on  >DEBUG:  removing temporary stats file "pg_stat_tmp/db_0.stat"
< 2019-03-21 13:11:25.913 IST  on  >DEBUG:  shmem_exit(-1): 0 before_shmem_exit callbacks to make
< 2019-03-21 13:11:25.913 IST  on  >DEBUG:  shmem_exit(-1): 0 on_shmem_exit callbacks to make
< 2019-03-21 13:11:25.913 IST  on  >DEBUG:  proc_exit(-1): 0 callbacks to make
< 2019-03-21 13:11:25.913 IST  on  >DEBUG:  server process (PID 4554) exited with exit code 1
< 2019-03-21 13:11:25.914 IST  on  >LOG:  all server processes terminated; reinitializing
< 2019-03-21 13:11:25.914 IST  on  >DEBUG:  shmem_exit(1): 0 before_shmem_exit callbacks to make
< 2019-03-21 13:11:25.914 IST  on  >DEBUG:  shmem_exit(1): 5 on_shmem_exit callbacks to make
< 2019-03-21 13:11:25.914 IST  on  >DEBUG:  cleaning up dynamic shared memory control segment with ID 478141041
< 2019-03-21 13:11:25.949 IST  on  >DEBUG:  invoking IpcMemoryCreate(size=148324352)
< 2019-03-21 13:11:25.950 IST  on  >DEBUG:  mmap(148897792) with MAP_HUGETLB failed, huge pages disabled: Cannot allocate memory
< 2019-03-21 13:11:25.962 IST  on  >DEBUG:  SlruScanDirectory invoking callback on pg_notify/0000
< 2019-03-21 13:11:25.962 IST  on  >DEBUG:  removing file "pg_notify/0000"
< 2019-03-21 13:11:25.963 IST  on  >DEBUG:  dynamic shared memory system will support 288 segments
< 2019-03-21 13:11:25.963 IST  on  >DEBUG:  created dynamic shared memory control segment 1748850970 (2316 bytes)
< 2019-03-21 13:11:25.964 IST  on  >LOG:  database system was interrupted; last known up at 2019-03-21 13:08:55 IST
< 2019-03-21 13:11:26.010 IST  on  >DEBUG:  checkpoint record is at 1/FC8B1D70
< 2019-03-21 13:11:26.010 IST  on  >DEBUG:  redo record is at 1/FC8B1D70; shutdown TRUE
< 2019-03-21 13:11:26.010 IST  on  >DEBUG:  next transaction ID: 0/105396; next OID: 129541
< 2019-03-21 13:11:26.010 IST  on  >DEBUG:  next MultiXactId: 1; next MultiXactOffset: 0
< 2019-03-21 13:11:26.010 IST  on  >DEBUG:  oldest unfrozen transaction ID: 1880, in database 1
< 2019-03-21 13:11:26.010 IST  on  >DEBUG:  oldest MultiXactId: 1, in database 17690
< 2019-03-21 13:11:26.010 IST  on  >DEBUG:  transaction ID wrap limit is 2147485527, limited by database with OID 1
< 2019-03-21 13:11:26.010 IST  on  >DEBUG:  MultiXactId wrap limit is 2147483648, limited by database with OID 17690
< 2019-03-21 13:11:26.010 IST  on  >DEBUG:  starting up replication slots
< 2019-03-21 13:11:26.010 IST  on  >LOG:  database system was not properly shut down; automatic recovery in progress
< 2019-03-21 13:11:26.011 IST  on  >DEBUG:  resetting unlogged relations: cleanup 1 init 0
< 2019-03-21 13:11:26.012 IST  on  >LOG:  record with zero length at 1/FC8B1DD8
< 2019-03-21 13:11:26.012 IST  on  >LOG:  redo is not required
< 2019-03-21 13:11:26.012 IST  on  >DEBUG:  resetting unlogged relations: cleanup 0 init 1
< 2019-03-21 13:11:26.014 IST  on  >DEBUG:  performing replication slot checkpoint
< 2019-03-21 13:11:26.030 IST  on  >DEBUG:  attempting to remove WAL segments older than log file 0000000000000001000000FB
< 2019-03-21 13:11:26.030 IST  on  >DEBUG:  SlruScanDirectory invoking callback on pg_multixact/offsets/0000
< 2019-03-21 13:11:26.030 IST  on  >DEBUG:  SlruScanDirectory invoking callback on pg_multixact/members/0000
< 2019-03-21 13:11:26.030 IST  on  >DEBUG:  oldest MultiXactId member is at offset 0
< 2019-03-21 13:11:26.030 IST  on  >LOG:  MultiXact member wraparound protections are now enabled
< 2019-03-21 13:11:26.030 IST  on  >DEBUG:  MultiXact member stop limit is now 4294914944 based on MultiXact 1
< 2019-03-21 13:11:26.030 IST  on  >DEBUG:  shmem_exit(0): 1 before_shmem_exit callbacks to make
< 2019-03-21 13:11:26.030 IST  on  >DEBUG:  shmem_exit(0): 3 on_shmem_exit callbacks to make
< 2019-03-21 13:11:26.030 IST  on  >DEBUG:  proc_exit(0): 2 callbacks to make
< 2019-03-21 13:11:26.030 IST  on  >DEBUG:  exit(0)
< 2019-03-21 13:11:26.030 IST  on  >DEBUG:  shmem_exit(-1): 0 before_shmem_exit callbacks to make
< 2019-03-21 13:11:26.030 IST  on  >DEBUG:  shmem_exit(-1): 0 on_shmem_exit callbacks to make
< 2019-03-21 13:11:26.030 IST  on  >DEBUG:  proc_exit(-1): 0 callbacks to make
< 2019-03-21 13:11:26.033 IST  on  >DEBUG:  checkpointer updated shared memory configuration values
< 2019-03-21 13:11:26.033 IST  on  >LOG:  database system is ready to accept connections
