[postgis-users] st_touches does not work with line/point real geometries
Sandro Santilli strk at kbt.io
Thu Mar 21 11:26:09 PDT 2019
On Thu, Mar 21, 2019 at 06:55:06PM +0100, Sandro Santilli wrote:
> BTW, it looks like one of the pictures in the example is wrong
> (the central line/line case). May be worth filing a ticket to
> fix that (even better if you send a patch for it :)
I was wrong, the example is correct. In that case the point in
common lies on the boundary of one of the lines, which makes
the Touches predicate true.
--strk;
