[postgis-users] st_touches does not work with line/point real geometries
Eugene Podshivalov
yaugenka at gmail.com
Thu Mar 21 12:14:58 PDT 2019
Now I got it. Thanks for the explanation.
It would be easier to comprehend it if there were some illustrations with
false cases in the documentation, particularly the line/point case and as
well as the line/line one with intersecting interiors.
Cheers,
Eugene
чт, 21 мар. 2019 г. в 21:49, Martin Davis <mtnclimb at gmail.com>:
> On Thu, Mar 21, 2019 at 11:17 AM Sandro Santilli <strk at kbt.io> wrote:
>> BTW, it looks like one of the pictures in the example is wrong
>> (the central line/line case). May be worth filing a ticket to
>> fix that (even better if you send a patch for it :)
>> Why do you think it's wrong?
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190321/3b379781/attachment.html>
