[postgis-users] Cache lookup failed for function 1 while activating PostGIS
Regina Obe
lr at pcorp.us
Mon Mar 25 07:00:35 PDT 2019
Some questions to troubleshoot:
1) I assume you did
CREATE EXTENSION postgis;
To enable it?
2) Can you create another extension and it works or you get same error. E.g. does
CREATE EXTENSION file_fdw;
Work? If so it's not a PostGIS issue and something wrong with your system or install.
That error often occurs if you had a server crash or something similar the corrupted system tables or indexes.
You could try to reindex the pg_proc table.
3) What version of PostGIS did you install?
Hope that helps,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of zakaria mouqcit
Sent: Monday, March 25, 2019 4:49 AM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Cache lookup failed for function 1 while activating PostGIS
I'm using PostgreSQL 10.5 on a remote server (Debian). I created a database inside then I attempted to enable PostGIS but it wasn't successful.
I had this error : cache lookup failed for function 1
MOUQCIT Zakaria - Ingénieur géomaticien
Sige | Mapping and Virtual reality
<http://www.sige.ma/> www.sige.ma
Bureau + 212 5 37 65 91 09 <tel:+%20212%205%2037%2065%2091%2009>
Mobile Maroc: +212 6 32 60 78 55 <tel:+%20212%207%2071%2093%2057%2038>
32 Rue Ouled Ziane, Aviation, Rabat, Maroc <http://osm.org/go/b4oZYrEhv--?layers=N&m=> Plan OSM, <https://www.google.fr/maps/place/Sige,+Soci%C3%A9t%C3%A9+d'ing%C3%A9nierie+g%C3%A9omatique+et+environnementale/@33.992439,-6.8260357,17z/data=!3m1!4b1!4m5!3m4!1s0xda76b6f50462d31:0xbf5c0d2cc4e237bc!8m2!3d33.992439!4d-6.823847> Gmaps
<http://www.sig-environnement.com/wp-content/uploads/sites/77/2017/03/signature.png>
Pour plus d'efficacité, nous consultons généralement nos e-mails à 11H et 16H. Pour les sujets urgents, merci de nous contacter par téléphone.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190325/62ea0f93/attachment.html>
