[postgis-users] error: by topology.topogeometry
paul.malm at lfv.se
paul.malm at lfv.se
Tue Mar 26 07:07:55 PDT 2019
Hi, when I run this sql queries
CREATE TABLE merged AS(
SELECT fname, the_geom FROM public."RST_1813_UTM31N_WE_D_R_Line"
UNION
SELECT fname, the_geom FROM public."CTR_1813_UTM31N_WE_line");
UPDATE merged set the_geom = st_makevalid(the_geom);
CREATE INDEX gid ON merged USING GIST ( the_geom );
SELECT Populate_Geometry_Columns('merged'::regclass);
SELECT topology.CreateTopology('roads_topo', 32631, 1.001);
SELECT topology.AddTopoGeometryColumn('roads_topo', 'public', 'merged', 'topo_geom', 'LINESTRING');
UPDATE merged SET topo_geom = topology.toTopoGeom(the_geom, 'roads_topo', 1, 0.001);
CREATE TABLE public."roads_clean" AS (
SELECT fname, topo_geom::geometry FROM merged);
SELECT topology.DropTopoGeometryColumn('public', 'merged', 'topo_geom');
SELECT topology.DropTopology('roads_topo');
I get the following error:
ERROR: Error: SQL/MM Spatial exception - geometry crosses edge 8618 CONTEXT: PL/pgSQL-function topology.totopogeom(geometry,topology.topogeometry,double precision) line 112 at FOR over SELECT-rows PL/pgSQL-function topology.totopogeom(geometry,character varying,integer,double precision) line 88 at assignment
The error appears at different edges when changing the tolerance on CreateTopology and toTopoGeom.
I added the ST_makeValid function call on the input data without any success.
Does anyone know what I can do?
Kind regards,
Paul
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190326/cd8fe2c8/attachment.html>
