[postgis-users] ST_Intersection does not preserve M value
Martin Davis mtnclimb at gmail.com
Mon May 6 09:36:09 PDT 2019
It should be possible to post-process GEOS results to re-populate the M
values if present.  Linear interpolation could be used to estimate values
at intra-segment points.  We can put this on the list for future
development.
On Mon, May 6, 2019 at 4:48 AM Darafei "Komяpa" Praliaskouski <me at komzpa.net>
wrote:
> Hi,
> GEOS operations do not preserve M, but sometimes preserve Z. You can try
> ST_SwapOrdinates(ST_Intersection(ST_SwapOrdinates(geom, 'zm'),...), 'zm').
> On Thu, May 2, 2019 at 5:19 AM Bo Guo <bo.guo at gisticinc.com> wrote:
>> Hi there,
>> I was trying to cut a portion of the LRS route with an area using
>> ST_Intersection.  However the resulting route no longer carries measure
>> value.  The behavior is the same for version 9.6 or the latest version
>> 11.  Anyone has any suggestions?
>> Thanks!
>> Bo
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
> Darafei Praliaskouski
> Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190506/5a652c44/attachment.html>
