[postgis-users] ST_Intersection does not preserve M value
Martin Davis
mtnclimb at gmail.com
Mon May 6 14:53:25 PDT 2019
Not exactly the same thing - I believe that ticket is referring to just the
WKB format handling?
I can make a ticket for measure handling by the overlay operations if there
isn't one already.
On Mon, May 6, 2019 at 11:31 AM Darafei "Komяpa" Praliaskouski <
me at komzpa.net> wrote:
> It's in backlog for 6 years already I believe:
> https://trac.osgeo.org/geos/ticket/466
> пн, 6 мая 2019, 19:33 карыстальнік Martin Davis <mtnclimb at gmail.com>
> напісаў:
>> It should be possible to post-process GEOS results to re-populate the M
>> values if present. Linear interpolation could be used to estimate values
>> at intra-segment points. We can put this on the list for future
>> development.
>> On Mon, May 6, 2019 at 4:48 AM Darafei "Komяpa" Praliaskouski <
>>> Hi,
>>> GEOS operations do not preserve M, but sometimes preserve Z. You can try
>>> ST_SwapOrdinates(ST_Intersection(ST_SwapOrdinates(geom, 'zm'),...), 'zm').
>>> On Thu, May 2, 2019 at 5:19 AM Bo Guo <bo.guo at gisticinc.com> wrote:
>>>> Hi there,
>>>> I was trying to cut a portion of the LRS route with an area using
>>>> ST_Intersection. However the resulting route no longer carries measure
>>>> value. The behavior is the same for version 9.6 or the latest version
>>>> 11. Anyone has any suggestions?
>>>> Thanks!
>>>> Bo
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>>> Darafei Praliaskouski
>>> Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190506/52fe1e38/attachment.html>
