[postgis-users] PostGIS + pgdump
James Keener jim at jimkeener.com
Thu May 16 06:12:56 PDT 2019
It'd help if you told us what errors you're getting.
Jim
On Thu, May 16, 2019 at 9:10 AM Zwettler Markus (OIZ) <
Markus.Zwettler at zuerich.ch> wrote:
> Hi,
> We did a default PostGIS installation within a PostgreSQL 9.6 database:
> create extension if not exists postgis;
> create extension if not exists postgis_topology;
> create extension if not exists ogr_fdw;
> create extension if not exists pgrouting;
> This installed PostGIS within the public schema of the database.
> (SET SCHEMA is not supported since V2.3 anymore)
> Our customer application was also installed within the public schema.
> When we pg_dump + pg_restore the database we got a lot of errors.
> We tried to pg_restore the dump into a database without postgis extension
> => postgis errors
> We tried to pg_restore the dump into a database with postgis extension =>
> postgis errors
> We tried to pg_restore only the public schema into a database with postgis
> extension => postgis errors
> QUESTION:
> How does the PostGIS extension have to be installed so that pg_dump +
> pg_restore DO NOT error out?
> Thanks,
> Markus
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190516/b95a191c/attachment.html>
