[postgis-users] aggregate different geometries
Regina Obe
lr at pcorp.us
Mon May 20 07:18:37 PDT 2019
Use ST_Collect (or ST_Union) instead of ST_MakeLine.
The difference between ST_Collect and ST_Union is in the case of polygons
you make end up with invalid multipolygon if your polygons overlap
In the case of linestring and point, your point will disappear if it
intersects the linestring if you use ST_Union.
ST_Collect will maintain your original geometries where as ST_Union will
collapse them if they have any intersection. In case of no intersection,
the results would be more or less the same except possibly ordered
differently.
SELECT e. foreign_key,
ST_Multi(ST_Collect(e.geom)) as geom
FROM gis_schema.single_objects e
GROUP BY e. foreign_key
Note to control order, you can always include an ORDER by clause in the
aggregate
e.g ST_Collect(e.geom ORDER BY e.some_field)
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Braune, Christopher
Sent: Monday, May 20, 2019 9:52 AM
To: 'postgis-users at lists.osgeo.org' <postgis-users at lists.osgeo.org>
Subject: [postgis-users] aggregate different geometries
Hello postgis-community,
I'm searching for a solution to create aggregated geometries from a table
with different single geometries. The input data looks like that:
id foreign_key geom
1 100 point
2 200 point
3 200 point
4 300 point
5 300 point
6 300 point
7 400 point
8 400 line
9 500 point
10 500 polygon
Now, I want to group this data by the "foreign_key". The result table have
to be this structure:
foreign_key geom
100 point * result of one point
200 line * result of two
points
300 polygon * result of three points
400 polygon * result of one line and
one point
500 polygon * result of one polygon
and one point
600 (.) * other combinations
The target is the smallest geometry that contains all single geometries. For
example, three points creates a triangle-polygon.
My last try looks like this:
ST_Multi(ST_makeline(e.geom)) as geom
(* Of course, polygons are not considered yet ;-)
Have anybody an idea? Thank's a lot!
Best regards,
Christopher
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190520/9fde4f02/attachment.html>
