[postgis-users] Any way of assigning a name alias to the system "postgres" database?
Jorge Gustavo Rocha
jgr at di.uminho.pt
Tue May 21 15:36:57 PDT 2019
Hi Bob,
In which context you want to use an alias?
If it is just for connecting to the database, check pg_services.conf
[1]. It allows you to use a name that will be resolved by the local
pg_service.conf file.
You can also use a client pool manager, like pgBouncer. It allows you to
use a local name, different from the database name.
I hope it helps.
Regards,
Jorge Gustavo
[1] https://www.postgresql.org/docs/11/libpq-pgservice.html
[2] https://pgbouncer.github.io/
Às 20:19 de 21/05/19, Basques, Bob (CI-StPaul) escreveu:
> All (trying PostGIS users first),
> I have a need to call it by another name, but also to leave it named as
> is for legacy stuff.
> Anyone know of a way to do this?
> Thanks
> bobb
> Those who believe in telekinetics, raise my hand.
> —Kurt Vonnegut
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
