[postgis-users] Status of PostGIS 3 and PostgreSQL Yum Repos?
Paul Ramsey
pramsey at cleverelephant.ca
Tue Nov 5 19:45:18 PST 2019
Do you have access to cachegrind or some other sampling profiler in
your environment? Maybe you can get a feel for where the cycles are
different? Also, does your proj install include a pgk-config? You
could check and see if the build flags differ between systems.
On Tue, Nov 5, 2019 at 7:32 PM Daryl Herzmann <akrherz at gmail.com> wrote:
> Greetings,
> I have created a reproducer in development and can run whatever
> command necessary to help debug this problem. I can't resolve what I
> should try though :) Any suggestions?
> daryl
> On Mon, Nov 4, 2019 at 9:34 PM Daryl Herzmann <akrherz at gmail.com> wrote:
> > Good evening Paul,
> > Thanks for the reply. Some more details:
> > RHEL7
> > # ldd /usr/pgsql-12/lib/postgis-3.so
> > linux-vdso.so.1 => (0x00007ffc7ef0b000)
> > libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007fbdc45b5000)
> > libgeos_c.so.1 => /usr/geos38/lib64/libgeos_c.so.1 (0x00007fbdc4378000)
> > libproj.so.15 => /usr/proj62/lib/libproj.so.15 (0x00007fbdc3eef000)
> > libjson-c.so.2 => /lib64/libjson-c.so.2 (0x00007fbdc3ce4000)
> > libprotobuf-c.so.1 => /lib64/libprotobuf-c.so.1 (0x00007fbdc3adb000)
> > libxml2.so.2 => /lib64/libxml2.so.2 (0x00007fbdc3771000)
> > libm.so.6 => /lib64/libm.so.6 (0x00007fbdc346f000)
> > libSFCGAL.so.1 => /lib64/libSFCGAL.so.1 (0x00007fbdc29ac000)
> > libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007fbdc2796000)
> > libc.so.6 => /lib64/libc.so.6 (0x00007fbdc23c8000)
> > /lib64/ld-linux-x86-64.so.2 (0x00007fbdc4beb000)
> > libgeos-3.8.0.so => /usr/geos38/lib64/libgeos-3.8.0.so (0x00007fbdc2000000)
> > libsqlite3.so.0 => /lib64/libsqlite3.so.0 (0x00007fbdc1d4b000)
> > libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fbdc1b2f000)
> > libdl.so.2 => /lib64/libdl.so.2 (0x00007fbdc192b000)
> > libz.so.1 => /lib64/libz.so.1 (0x00007fbdc1715000)
> > liblzma.so.5 => /lib64/liblzma.so.5 (0x00007fbdc14ef000)
> > libCGAL.so.11 => /usr/lib64/libCGAL.so.11 (0x00007fbdc12c7000)
> > libCGAL_Core.so.11 => /usr/lib64/libCGAL_Core.so.11 (0x00007fbdc108e000)
> > libmpfr.so.4 => /usr/lib64/libmpfr.so.4 (0x00007fbdc0e33000)
> > libgmp.so.10 => /usr/lib64/libgmp.so.10 (0x00007fbdc0bbb000)
> > libboost_date_time-mt.so.1.53.0 =>
> > /usr/lib64/libboost_date_time-mt.so.1.53.0 (0x00007fbdc09aa000)
> > libboost_thread-mt.so.1.53.0 =>
> > /usr/lib64/libboost_thread-mt.so.1.53.0 (0x00007fbdc0793000)
> > libboost_system-mt.so.1.53.0 =>
> > /usr/lib64/libboost_system-mt.so.1.53.0 (0x00007fbdc058f000)
> > libboost_serialization-mt.so.1.53.0 =>
> > /usr/lib64/libboost_serialization-mt.so.1.53.0 (0x00007fbdc0323000)
> > librt.so.1 => /usr/lib64/librt.so.1 (0x00007fbdc011b000)
> > RHEL8
> > linux-vdso.so.1 (0x00007ffcb9f66000)
> > libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007ff53a841000)
> > libgeos_c.so.1 => /usr/geos38/lib64/libgeos_c.so.1 (0x00007ff53a602000)
> > libproj.so.15 => /usr/proj62/lib/libproj.so.15 (0x00007ff53a175000)
> > libjson-c.so.4 => /lib64/libjson-c.so.4 (0x00007ff539f65000)
> > libprotobuf-c.so.1 => /lib64/libprotobuf-c.so.1 (0x00007ff539d5c000)
> > libxml2.so.2 => /lib64/libxml2.so.2 (0x00007ff5399f4000)
> > libm.so.6 => /lib64/libm.so.6 (0x00007ff539672000)
> > libSFCGAL.so.1 => /lib64/libSFCGAL.so.1 (0x00007ff53897b000)
> > libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007ff538763000)
> > libc.so.6 => /lib64/libc.so.6 (0x00007ff53839f000)
> > /lib64/ld-linux-x86-64.so.2 (0x00007ff53af0e000)
> > libgeos-3.8.0.so => /usr/geos38/lib64/libgeos-3.8.0.so (0x00007ff537fcc000)
> > libsqlite3.so.0 => /lib64/libsqlite3.so.0 (0x00007ff537cb9000)
> > libpthread.so.0 => /lib64/libpthread.so.0 (0x00007ff537a99000)
> > libdl.so.2 => /lib64/libdl.so.2 (0x00007ff537895000)
> > libz.so.1 => /lib64/libz.so.1 (0x00007ff53767e000)
> > liblzma.so.5 => /lib64/liblzma.so.5 (0x00007ff537457000)
> > libCGAL_Core.so.13 => /usr/lib64/libCGAL_Core.so.13 (0x00007ff5371b7000)
> > libboost_thread.so.1.66.0 => /usr/lib64/libboost_thread.so.1.66.0
> > (0x00007ff536f8b000)
> > libboost_system.so.1.66.0 => /usr/lib64/libboost_system.so.1.66.0
> > (0x00007ff536d86000)
> > libboost_serialization.so.1.66.0 =>
> > /usr/lib64/libboost_serialization.so.1.66.0 (0x00007ff536b45000)
> > libboost_chrono.so.1.66.0 => /usr/lib64/libboost_chrono.so.1.66.0
> > (0x00007ff53693c000)
> > libboost_date_time.so.1.66.0 =>
> > /usr/lib64/libboost_date_time.so.1.66.0 (0x00007ff536729000)
> > libboost_atomic.so.1.66.0 => /usr/lib64/libboost_atomic.so.1.66.0
> > (0x00007ff536527000)
> > libCGAL.so.13 => /usr/lib64/libCGAL.so.13 (0x00007ff536308000)
> > libmpfr.so.4 => /usr/lib64/libmpfr.so.4 (0x00007ff5360a4000)
> > libgmp.so.10 => /usr/lib64/libgmp.so.10 (0x00007ff535e0e000)
> > librt.so.1 => /usr/lib64/librt.so.1 (0x00007ff535c05000)
> > So RHEL8 has CGAL-4.14-1.rhel8.x86_64, whereas RHEL7 has
> > CGAL-4.7-1.rhel7.1.x86_64
> > This RHEL7 host was performing fine with previous PostgreSQL + Postgis
> > releases. Wonder what I could have fouled up....
> > daryl
> > On Mon, Nov 4, 2019 at 9:18 PM Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> > > 40x is shocking and it looks like the only difference is red hat 7 vs 8.?
> > > > On Nov 4, 2019, at 6:47 PM, Daryl Herzmann <akrherz at gmail.com> wrote:
> > > > Thanks for the response Raúl,
> > > > I tried PostGIS 3.0 GA now on RHEL7 and am still seeing the same
> > > > puzzling slow behaviour. My RHEL8 development laptop crunches the
> > > > same data through ST_Transform() in excellent time. Here's a
> > > > comparison of the explain analyze on both hosts
> > > > RHEL7
> > > > POSTGIS="3.0.0 r17983" [EXTENSION] PGSQL="120"
> > > > GEOS="3.8.0-CAPI-1.13.1 " PROJ="6.2.0" LIBXML="2.9.1" LIBJSON="0.11"
> > > > LIBPROTOBUF="1.0.2" WAGYU="0.4.3 (Internal)"
> > > > explain analyze select st_transform(geom, 2163) from stations;
> > > > QUERY
> > > > PLAN
> > > > Gather (cost=1000.00..113124.15 rows=69980 width=32) (actual
> > > > time=3535.920..4624.442 rows=70025 loops=1)
> > > > Workers Planned: 1
> > > > Workers Launched: 1
> > > > -> Parallel Seq Scan on stations (cost=0.00..105126.15 rows=41165
> > > > width=32) (actual time=4061.506..4104.824 rows=35012 loops=2)
> > > > Planning Time: 0.057 ms
> > > > Execution Time: 4627.474 ms
> > > > RHEL8
> > > > GEOS="3.8.0-CAPI-1.13.1 " PROJ="6.2.0" LIBXML="2.9.7" LIBJSON="0.13.1"
> > > > LIBPROTOBUF="1.3.0" WAGYU="0.4.3 (Internal)"
> > > > QUERY PLAN
> > > > Gather (cost=1000.00..112529.32 rows=69618 width=32) (actual
> > > > time=46.818..90.248 rows=69618 loops=1)
> > > > Workers Planned: 1
> > > > Workers Launched: 1
> > > > -> Parallel Seq Scan on stations (cost=0.00..104567.52 rows=40952
> > > > width=32) (actual time=49.211..72.335 rows=34809 loops=2)
> > > > Planning Time: 0.036 ms
> > > > Execution Time: 91.871 ms
> > > > I don't have an exact copy of the data between the two hosts, but it is close.
> > > > thanks
> > > > daryl
> > > >> On Wed, Oct 30, 2019 at 8:58 AM <rmrodriguez at carto.com> wrote:
> > > >> The are waiting for GDAL 3.0.2 to be out to package them together.
> > > >> Source: https://twitter.com/DevrimGunduz/status/1189216750895882243
> > > >> In any case, ST_Transform is slower because PROJ6 is slower, but it
> > > >> shouldn't be that slow.
> > > >>> On Wed, Oct 30, 2019 at 2:54 PM Daryl Herzmann <akrherz at gmail.com> wrote:
> > > >>> Greetings,
> > > >>> Does anybody know what's going on with the PostgreSQL Yum repos
> > > >>> supporting PostGIS 3? The repos continue to be stuck with 3.0 alpha4
> > > >>> https://yum.postgresql.org/12/redhat/rhel-7-x86_64/
> > > >>> I am having issues with performance with that alpha4 release and am
> > > >>> hoping they magically go away with the GA release of version 3 :)
> > > >>> https://redmine.postgresql.org/issues/4826
> > > >>> Is there some public interface to see the build status results of these RPMs?
> > > >>> thanks
> > > >>> daryl
> > > >>> _______________________________________________
> > > >>> postgis-users mailing list
> > > >>> postgis-users at lists.osgeo.org
> > > >>> https://lists.osgeo.org/mailman/listinfo/postgis-users
> > > >> Raúl Marín Rodríguez
> > > >> carto.com
