[postgis-users] Looking for information for allowing Office 365 Excel to access and use map data stored on PostGIS.
Stefan Wolf
sw at zpmt.de
Tue Nov 12 07:54:16 PST 2019
That’s right – PostGIS itself doesn‘t produce any maps – only GEOMETRIES as POINTs, POLYGONs etc.
PostGIS can produce the Query-Result “AsGeoJSON“ (an open Standard-Format).
Bing Maps (and others) can “read” and disply this GeoJSON …
Regards
-Stefan-
Von: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] Im Auftrag von Shaozhong SHI
Gesendet: Dienstag, 12. November 2019 16:43
An: PostGIS Users Discussion
Betreff: Re: [postgis-users] Looking for information for allowing Office 365 Excel to access and use map data stored on PostGIS.
Thanks, Stefan,
I can load in tables, but geometry column contains codes only. It does not show up as a map.
Regards,
Shao
On Tue, 12 Nov 2019 at 13:10, Stefan Wolf <sw at zpmt.de> wrote:
Google for: odbc pass through query
SQL pass-through queries are used to send commands directly to an ODBC database server. By using an SQL pass-through query, you work directly with the server tables instead of having the Microsoft Jet database engine process the data.
You can use “normal” PostgreSQL-SQL syntax like in pgAdmin…
Regards
-Stefan-
Gesendet: Dienstag, 12. November 2019 13:26
Betreff: [postgis-users] Looking for information for allowing Office 365 Excel to access and use map data stored on PostGIS.
Has anyone got such information?
Looking forward to hearing from you.
Regards,
Shao
postgis-users mailing list
postgis-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191112/0835d948/attachment.html>
