[postgis-users] raster2pgsql fail with JPEG encoded image
Jorge Gustavo Rocha
jgr at di.uminho.pt
Tue Oct 1 15:32:49 PDT 2019
Thank you Pierre and Jim for your comments.
It is definitely related with the raster "GeoTransform". raster2pgsql
does handles it properly, but not in all circumstances.
I've looked at GDAL GetGeoTransform. It reads properly the necessary
transformation. I've wrote a small python script to iterate all over the
files just to report:
print("GetGeoTransform={}".format(dataset.GetGeoTransform()))
All (failing in raster2pgsql) test files have GeoTransform matrices. If
I open these rasters directly in QGIS, for example, the matrix is
respected and applied.
When I load those rasters into Postgis with raster2pgsql, the
GeoTransformation is not applied correctly.
There are several calls to GDALApplyGeoTransform in rasper2pgsql code. I
need more detailed verbose/debug output to see exactly which
transformation is applied (and how the math is done).
Next step: debug raster2pgsql for such matrices. It is not my expertise,
but I need raster2pgsql running for all kind of rasters.
I'll keep looking at this issue and I'll report back.
Tanks for the comments.
Regards,
Jorge
Às 20:25 de 30/09/19, Jim Klassen escreveu:
> It's been awhile, but I think when I ran into this last, running the
> image through gdal_warp first rewrote the image as North up.
> On 9/30/19 12:26 PM, Pierre Racine wrote:
>> GDAL is complaining that your image is rotated and that it does not
>> support it yet. What if you erase (or just rename) the .jgw,
>> temporally to remove the rotation?
>> Pierre
>> -----Message d'origine-----
>> De : postgis-users <postgis-users-bounces at lists.osgeo.org> De la part
>> de Jorge Gustavo Rocha
>> Envoyé : 27 septembre 2019 18:18
>> À : PostGIS Users Discussion <postgis-users at lists.osgeo.org>
>> Objet : [postgis-users] raster2pgsql fail with JPEG encoded image
>> Hi Postgisers,
>> I'm trying to find out why a particular JPEG image does not work with
>> raster2pgsql.
>> I've described the problem as a question in gis.stackexchange:
>> https://gis.stackexchange.com/questions/337127/raster2pgsql-fail-with-jpeg-encoded-image
>> There are no errors when inserting the raster in the database.
>> gdalinfo works fine, both with the original image and the Postgis raster.
>> The only error I got is if I try to save the Postgis raster back to a
>> file system image, like:
>> gdal_translate -of JPEG PG:"service=pg_geotuga dbname=geotuga
>> When I do this, I get the error: "GDAL PostGIS Raster driver can not
>> work with rotated rasters yet." (but the image is written, but I'm not
>> able to render it).
>> I suspect that the encoding/compression of this specific image is not
>> supported.
>> identify '05-D Braga.jpg'
>> 05-D Braga.jpg JPEG 10614x7739 10614x7739+0+0 8-bit sRGB 11.1453MiB
>> 0.000u 0:00.000
>> This is just one of the many geological rasters of the country. I
>> would like to upload them all to Postgis. I can recode the images, if
>> necessary, but even changing them from JPEG to GTiff is not enough.
>> Preferably, I would like to identify and maybe fix the issue in
>> raster2pgsql.
>> The GDAL version reported by Postgis is 2.3.2 (does it use static
>> libs?). The GDAL version on the system is 3.0.1.
>> raster2pgsql -?
>> RELEASE: 2.5.2 GDAL_VERSION=23 (r17328)
>> gdalinfo --version
>> GDAL 3.0.1, released 2019/06/28
>> select postgis_full_version();
>> POSTGIS="2.5.2 r17328" [EXTENSION] PGSQL="110" GEOS="3.7.0-CAPI-1.11.0
>> 673b9939" PROJ="Rel. 5.2.0, September 15th, 2018" GDAL="GDAL 2.3.2,
>> released 2018/09/21" LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.3.1"
>> RASTER
>> The database has raster support enabled and I can upload other rasters
>> to the database without any issues.
>> Best regards,
>> Jorge Gustavo
>> Jorge Gustavo Rocha
>> Departamento de Informática
>> Universidade do Minho
>> 4710-057 Braga
>> Gabinete 3.29 (Piso 3)
>> Tel: +351 253604480
>> Fax: +351 253604471
>> Móvel: +351 910333888
>> skype: nabocudnosor
>> postgis-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
J. Gustavo
Jorge Gustavo Rocha
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
skype: nabocudnosor
