[postgis-users] Query postgis GUC variables on a new connection
Jorge Gustavo Rocha
jgr at di.uminho.pt
Sun Oct 27 10:25:54 PDT 2019
When I connect to a database, I can not query the postgis GUC variables
postgis.enable_outdb_rasters or postgis.gdal_enabled_drivers.
$ psql service=geotuga
psql (11.4 (Ubuntu 11.4-1.pgdg18.10+1))
SSL connection (protocol: TLSv1.3, cipher: TLS_AES_256_GCM_SHA384, bits:
256, compression: off)
localhost:5432 geobox at geotuga=# show postgis.gdal_enabled_drivers;
ERROR: 42704: unrecognized configuration parameter
"postgis.gdal_enabled_drivers"
localhost:5432 geobox at geotuga=# show postgis.enable_outdb_rasters;
"postgis.enable_outdb_rasters"
But if I run ST_GDALDrivers(), afterwards the variables can be queried.
localhost:5432 geobox at geotuga=# SELECT short_name FROM ST_GDALDrivers()
LIMIT 1;
short_name
VRT
on
ENABLE_ALL
My question is: aren't these variables already assigned? Why only after
ST_GDALDrivers() call are these variables defined?
Best regards
Jorge Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Gabinete 3.29 (Piso 3)
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
