[postgis-users] Query postgis GUC variables on a new connection
Sandro Santilli strk at kbt.io
Mon Oct 28 00:32:09 PDT 2019
On Sun, Oct 27, 2019 at 03:52:37PM -0700, Paul Ramsey wrote:
> Until the library loads the system doesn’t know about the GUCs. And querying the GUCs doesn’t for a library load (the system doesn’t having a binding from GUC to library). Querying a function, on the other hand, forces a load.
> If this really annoys you, add postgis_raster.so to the ld_preload config in postgresql.conf.
For the record, you can also use:
  LOAD '$libdir/postgis_raster-3.so'
Directly in the sql session
--strk;
