[postgis-users] Can psql copy gml into postgis?
Shaozhong SHI
shishaozhong at gmail.com
Mon Sep 2 07:27:20 PDT 2019
Hi, Simon,
That is very interesting.
Thank you.
Regards,
Shao
On Mon, 2 Sep 2019 at 10:36, Simon (SPDBA) Greener <
simon at spatialdbadvisor.com> wrote:
> Here are two simple examples I've created.
> Hope they are useful.
> https://www.spdba.com.au/?p=599
> Simon
> 39 Cliff View Drive, Allens Rivulet, Tas 7150
> (H) 0362396397
> (M) 0418396391
> <http://www.spatialdbadvisor.com>www.spatialdbadvisor.com /
> <http://www.spdba.com.au>www.spdba.com.au
> Sent from BlueMail <http://www.bluemail.me/r?b=15487>
> On 2 Sep. 2019, at 05:29, "Simon (SPDBA) Greener" <
>> Yes it does.
>> I will post an example this week.
>> Simon
>> (H) 0362396397
>> (M) 0418396391
>> <http://www.spatialdbadvisor.com> www.spatialdbadvisor.com /
>> <http://www.spdba.com.au> www.spdba.com.au
>> On 1 Sep. 2019, at 23:42, Shaozhong SHI < shishaozhong at gmail.com> wrote:
>>> Hi, Simon,
>>> Thanks.
>>> Does that mean XML xquery can been run in psql command line?
>>> Regards,
>>> Shao
>>> On Sunday, 1 September 2019, Simon (SPDBA) Greener <
>>>> Yes.
>>>> One method is to copy the gml into a table (column declared as text or
>>>> xml). Then use XML XQUERY processing to shred the GML document into nodes
>>>> that ST_GeomFromGML() can consume.
>>>> Simon
>>>> <https://www.google.com/maps/search/39+Cliff+View+Drive,+Allens+Rivulet,+Tas+7150?entry=gmail&source=g>
>>>> (H) 0362396397
>>>> (M) 0418396391
>>>> On 1 Sep. 2019, at 16:57, Shaozhong SHI < shishaozhong at gmail.com>
>>>> wrote:
>>>>> Hi, all,
>>>>> Regards,
>>>>> Shao
>>>>> postgis-users mailing list
>>>>> postgis-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190902/fcd3f27b/attachment.html>
