[postgis-users] Upgrade issues
James Sewell james.sewell at jirotech.com
Mon Sep 2 17:40:59 PDT 2019
Ahhhhh  fyou thought fixed in 2.5.3?
I'm on 2.5.1.
Cheers,
James Sewell,
*Chief Architect*
[image: http://jirotech.com/jirotech.png]
Suite 112, Jones Bay Wharf, 26-32 Pirrama Road, Pyrmont NSW 2009
*P *(+61) 2 8099 9000 <(+61)%202%208099%209000>  *W* www.jirotech.com  *F *
(+61) 2 8099 9099 <(+61)%202%208099%209000>
On Tue, 3 Sep 2019 at 10:31, James Sewell <james.sewell at jirotech.com> wrote:
> Sadly that's not the case - the issue is with the actual Geometry column.
> ERROR:  relation "public.spatial_ref_sys" does not exist
> LINE 21:     location_pt public.geography(Point,4283),
> I'm curious how this ever worked?
> *James*
> On Tue, 3 Sep 2019 at 09:35, Regina Obe <lr at pcorp.us> wrote:
>> I recall Raúl  mentioning he triggered this.  I think he had something
>> like a table constraint on ST_Buffer(geog.. ) or some other function that
>> internally relies on spatial_ref_sys.
>> The issue is that since spatial_ref_sys is a table, pg_upgrade doesn’t
>> populate before it populates other tables. pg_upgrade first makes the
>> structure of all the tables and pg_upgrade doesn’t know it needs to
>> populate the data in spatial_ref_sys before the other tables as it does a
>> create extensions in non-standard way when migrating the data to maintain
>> same exact functions/data etc as it had before.
>> I thought we fixed this issue like in 2.5.3, but I I can’t find the bug
>> fix notice in the notices, so maybe not.  I also can’t remember what ticket
>> it was but I think it is ticketed.
>> What you could do is drop the offending constraint before you pg_upgrade,
>> and then create it after the upgrade is done.
>> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
>> Behalf Of *James Sewell
>> *Sent:* Sunday, September 1, 2019 10:59 PM
>> *To:* postgis-users at lists.osgeo.org
>> *Subject:* [postgis-users] Upgrade issues
>> Hi all,
>> I'm upgrading from 9.6 -> 11. Both versions have PostGIS 2.5.1.
>> The upgrade starts then I see this in the logs:
>> pg_restore: [archiver (db)] could not execute query: ERROR:  relation
>> LINE 39:     "location_pt" "public"."geography"(Point,4283),
>> Above this I can see:
>> pg_restore: creating EXTENSION "postgis"
>> This is created fine - it just doesn't make the PostGIS tables in any
>> schema?
>> Has anyone seen anything like this before?
>> Cheers,
>> James Sewell,
>> The contents of this email are confidential and may be subject to legal
>> or professional privilege and copyright. No representation is made that
>> this email is free of viruses or other defects. If you have received this
>> communication in error, you may not copy or distribute any part of it or
>> otherwise disclose its contents to anyone. Please advise the sender of your
>> incorrect receipt of this correspondence.
>> postgis-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
The contents of this email are confidential and may be subject to legal or
professional privilege and copyright. No representation is made that this
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190903/0c07636b/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190903/0c07636b/attachment.png>
