[postgis-users] Linestrings and MultiLiestrings to Linestrings
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Mon Sep 2 20:36:43 PDT 2019
https://gis.stackexchange.com/questions/49950/converting-mulitlinestring-to-linestring-in-postgresql-with-postgis/49994
If you simply want to have a single type in your table it's much easier
to convert the linestrings to mutilinestrings using this command like this
|ALTERTABLEmy_table ALTERCOLUMNgeom TYPE
geometry(MultiLineString,4326)USINGST_Multi(geom);|
(You'll have change the above command regarding table- and column names
and crs id)
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 02-09-2019 kl. 09:23 skrev paul.malm at lfv.se:
> Hi,
> I have a table (bufferedlines) with a geometry column (the_geom)
> including both Linestrings and MultiLinestrings, what is the easiest
> way to change the_geom to a Linestring column?
> Kind regards,
> Paul
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190903/69ee3117/attachment.html>
