[postgis-users] [postgis-devel] Upgrade issues
James Sewell
james.sewell at jirotech.com
Tue Sep 3 19:59:02 PDT 2019
On Wed, 4 Sep 2019 at 12:52, Regina Obe <lr at pcorp.us> wrote:
> Is this the first time you are running pg_upgrade?
On this database, yes.
> 1) I think most users don’t even know they can use an srid other
> than 4326 for geography, so this probably hasn’t been exercised by many
> users
Yeah that makes sense! I actually haven't seen this in the wild before
either.
> 2) This would not be an issue with regular PostGIS upgrade – ALTER
> EXTENSION postgis UPDATE;
This is a Postgres upgrade, yes (not a PostGIS upgrade).
> 3) It’s because pg_upgrade tries to replicate exactly what you had
> by first creating an empty PostGIS extension and then loading in all the
> extension parts from the database. In theory it should recognize that
> spatial_ref_sys is a part of PostGIS, so I’m very surprised you run into a
> situation where spatial_ref_sys table doesn’t exist. The spatial_ref_sys
> table being empty is a bit more understandable.
It happens when the user table is in a schema which sorts before the schema
spatial_ref_sys is in - maybe this one can be fixed with pg_depends rules.
Being empty, yeah I don't know how to fix than *and* still allow people to
insert custom projections.
> 4) I think also there was a time when the geography SRIDs were
> cached in a secret place, so geography didn’t rely on spatial_ref_sys. I
> forget when this changed (might have been at 2.2 or 2.3).
Hmm. Interesting.
The contents of this email are confidential and may be subject to legal or
professional privilege and copyright. No representation is made that this
email is free of viruses or other defects. If you have received this
communication in error, you may not copy or distribute any part of it or
otherwise disclose its contents to anyone. Please advise the sender of your
incorrect receipt of this correspondence.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190904/2dab11e8/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190904/2dab11e8/attachment.png>
