[postgis-users] breake lines
Martin Davis mtnclimb at gmail.com
Fri Sep 6 10:37:54 PDT 2019
On Fri, Sep 6, 2019 at 5:48 AM <paul.malm at lfv.se> wrote:
> Hi, I’ve succeeded in creating the table as you suggested Martin
> (Thanks!). With some small modifications (CollectionExtract etc.)
> The problem is that I would like to transfer all attributes from the
> original file to the result file. I’ve tried so many ways but I can’t get
> it right.
You'll probably have to name all the attribute columns you want to keep in
the SELECT list.
This would be easier & more reusable if Postgres supported SELECT * EXCEPT
( ...) (a la H2 [1])
[1] https://h2database.com/html/grammar.html#wildcard_expression
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190906/f993ec18/attachment.html>
