[postgis-users] Could someone explain the difference
paul.malm at lfv.se
paul.malm at lfv.se
Mon Sep 9 07:53:41 PDT 2019
Could someone please tell me why I don't get this to work?
I have one layer with lines and one layer with polygons. The lines are broken in the intersections of the polygons.
I would like to save a new layer with all lines inside the polygons and update the orig layer without those lines:
CREATE TABLE removedlines AS SELECT s.*
FROM orglines s
LEFT JOIN polygons h ON
ST_Contains(h.the_geom, s.the_geom)
WHERE
h.the_geom IS NOT NULL;
DELETE FROM removedlines WHERE ST_Length(the_geom) <= 2000
This seems ok!
Then I would like to remove the same lines from orglines, so that I have one layer with only the lines inside and > 2000 (that I have)
and one layer without those lines.
I tried to erase those lines from the orgline layer like this:
DELETE FROM orglines
WHERE id IN (
SELECT s.id FROM orglines AS s
LEFT OUTER JOIN polygons AS h ON
(ST_Contains(h.the_geom, s.the_geom)
AND St_Length(s.the_geom) > 2000)
WHERE h.the_geom IS NOT NULL)
I thought that only the iines inside and > 2000 should be erased but there were more lines erased than I thought.
I think the two sql sequences correspond, can someone explain to me why they don't
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190909/a3c33f86/attachment.html>
