[postgis-users] raster2pgsql fail with JPEG encoded image
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Mon Sep 30 10:26:15 PDT 2019
GDAL is complaining that your image is rotated and that it does not support it yet. What if you erase (or just rename) the .jgw, temporally to remove the rotation?
Pierre
-----Message d'origine-----
De : postgis-users <postgis-users-bounces at lists.osgeo.org> De la part de Jorge Gustavo Rocha
Envoyé : 27 septembre 2019 18:18
À : PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Objet : [postgis-users] raster2pgsql fail with JPEG encoded image
Hi Postgisers,
I'm trying to find out why a particular JPEG image does not work with raster2pgsql.
I've described the problem as a question in gis.stackexchange:
https://gis.stackexchange.com/questions/337127/raster2pgsql-fail-with-jpeg-encoded-image
There are no errors when inserting the raster in the database.
gdalinfo works fine, both with the original image and the Postgis raster.
The only error I got is if I try to save the Postgis raster back to a file system image, like:
gdal_translate -of JPEG PG:"service=pg_geotuga dbname=geotuga schema=raster table=geologica mode=2" 05.jpg
When I do this, I get the error: "GDAL PostGIS Raster driver can not work with rotated rasters yet." (but the image is written, but I'm not able to render it).
I suspect that the encoding/compression of this specific image is not supported.
identify '05-D Braga.jpg'
05-D Braga.jpg JPEG 10614x7739 10614x7739+0+0 8-bit sRGB 11.1453MiB 0.000u 0:00.000
This is just one of the many geological rasters of the country. I would like to upload them all to Postgis. I can recode the images, if necessary, but even changing them from JPEG to GTiff is not enough.
Preferably, I would like to identify and maybe fix the issue in raster2pgsql.
The GDAL version reported by Postgis is 2.3.2 (does it use static libs?). The GDAL version on the system is 3.0.1.
raster2pgsql -?
RELEASE: 2.5.2 GDAL_VERSION=23 (r17328)
gdalinfo --version
GDAL 3.0.1, released 2019/06/28
select postgis_full_version();
POSTGIS="2.5.2 r17328" [EXTENSION] PGSQL="110" GEOS="3.7.0-CAPI-1.11.0 673b9939" PROJ="Rel. 5.2.0, September 15th, 2018" GDAL="GDAL 2.3.2, released 2018/09/21" LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.3.1"
RASTER
The database has raster support enabled and I can upload other rasters to the database without any issues.
Best regards,
Jorge Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Gabinete 3.29 (Piso 3)
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
