[postgis-users] Refresh materialized view only when it's necessary
Guillaume ARNAUD
guillaume.arnaud at ledepartement82.fr
Wed Apr 1 08:11:12 PDT 2020
Hello, I need to refresh a materialized view in my database, but I only
want to do it when necessary. I use the materialized view because the
view costs more than 20 seconds. It's a big table. If I refresh with
trigger on the table that is used, after each update, I wait 20s ... I
have considered several solutions but I can't seem to put them in place.
They may not be possible ... Is there one you know? I thought of : - Put
a trigger on the tables used by the materialized view: Slow - delay
updating the view materialized with notify / listen but I didn't
understand how it works and send a request when the listen receives the
notification. - Search for an asynchronous update of the materialized
view: without success - Create a view of the materialized view to add a
rule on select: without success - Create a view of the materialized view
with in the call to the function that checks if the view is up to date
(using a third-party table): error cannot execute REFRESH MATERIALIZED
VIEW because this object is being use by active requests in this session
Do you have any idea to do this ? Thanks
Logo CD82 <http://www.ledepartement.fr> Guillaume ARNAUD
Technicien SIG
Cellule SIGD
Direction des systèmes informatiques et de télécommunication
Pôle coordination et ressources
Tél : 05 63 91 82 37
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200401/e3959b35/attachment.html>
