[postgis-users] Slow MapAlgebra performance
Быков Кирилл Валерьевич
kvbykov at edu.hse.ru
Mon Apr 6 11:57:27 PDT 2020
Dear All!
I calculate vegetation indices on rasters (Landsat 8 scenes).
The calculation of SAVI=(NIR-RED)/(NIR+RED+L)*(1+L) takes about 2 minutes to complete.
This is enormous time compared to the same operation in QGIS which takes several seconds.
Here is the query (it’s defined as postgres UDF and $1 parameter is L):
BEGIN
DROP TABLE IF EXISTS savi;
CREATE TABLE savi AS
SELECT bandt5.rid, ST_MapAlgebra(
bandt4.rast,
bandt5.rast,
'CASE WHEN ([rast2.val] + [rast1.val] = 0) THEN NULL ELSE (([rast2.val] - [rast1.val])*(1+$1) / ([rast2.val] + [rast1.val]+$1)::float) END', '32BF'
FROM bandt5, bandt4 WHERE bandt5.rid=bandt4.rid;
RETURN 1;
END;
I used the data from USGS, Landsat 8 Level 2, bands are stored in separate tables.
DB indices are created for every band by raster2pgsql.
Tile size is 128x128.
The whole raster2pgsql command: for each tif band:
"raster2pgsql -s 4326 -N -32767 -t 128x128 -I -C -M -d bandX.tif public.bandtX > bandX.sql".
Afterwards bandX.sql files were ingested by psql.
Are there any ways to improve the performance?
Thank you!
Regards,
Kirill
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200406/b3194d3b/attachment.html>
