[postgis-users] PostGIS Install
Regina Obe
lr at pcorp.us
Tue Apr 7 13:44:40 PDT 2020
Which link are you talking about? The PostGIS one doesn't reach to download
anything else.
I think the PostgreSQL 12 might reach out to download VS Runtime if you
don't have it, I forget which runtime it uses I think VS 2015-2019 runtime.
But I'm not sure of that.
If you use the application stack builder installed via PostgreSQL 12, it
will reach out to download PostGIS, but you don't need to go thru
application stackbuilder
All application stackbuilder does is download the files posted in
https://download.osgeo.org/postgis/windows/ for your version of PostgreSQL.
(which is also posted here - https://www.postgresql.org/ftp/postgis/ )
You can just install it directly without going thru application builder if
you know what version of PostgreSQL you are running.
Hope that helps,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of irwinrp at simulyze.com
Sent: Tuesday, April 7, 2020 3:28 PM
To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] PostGIS Install
Thank you for the link download but I am pretty sure it is one I have tried
and when you install PostGIS it reaches out to the WWW to download items and
the machine I am putting it on cannot be connected to the WWW.
Richard Irwin
Snr Systems Analyst/FSO
Simulyze Inc.
W 703-391-7001 ext 268
C 703-391-7001
From: postgis-users <postgis-users-bounces at lists.osgeo.org
<mailto:postgis-users-bounces at lists.osgeo.org> > On Behalf Of Regina Obe
Sent: Tuesday, April 7, 2020 1:30 PM
<mailto:postgis-users at lists.osgeo.org> >
Yes. You can download the executable for your specific PostgreSQL version
directly from
Note you do need PostgreSQL installed first which you can get from here:
https://www.postgresql.org/download/windows/
Thanks,
Regina
Of irwinrp at simulyze.com <mailto:irwinrp at simulyze.com>
Sent: Tuesday, April 7, 2020 9:16 AM
To: postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
Subject: [postgis-users] PostGIS Install
Can I install PostGIS on a windows server 2016 without any access to the
WWW?
Richard Irwin
Simulyze Inc.
C 703-391-7001
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200407/5de178cc/attachment.html>
