[postgis-users] Differences in st_transform between Postgis 2.3 and Postgis 3.0
rmrodriguez at carto.com rmrodriguez at carto.com
Thu Apr 23 06:12:39 PDT 2020
What proj releases are you using? `Select postgis_full_version()` will show it.
It is likely that your 3.0 is using PROJ6+ which has more precise
transformations.
On Thu, Apr 23, 2020 at 2:55 PM David McKelvie <dmck at interactive.co.uk> wrote:
> Hello;
> Ive noticed a difference between the results returned by st_transform
> between Postgis 2.3 and Postgis 3.0 and wonder if anyone on this list
> might be able to explain why that is so.
> I have a home rolled entry in the spatial_ref_sys table for a SRID called
> 927700.  This is the UK Ordnance Survey coordinate system using OSTN02.
> The spatial_ref_sys.proj4text for this is
> (newline added for readability)
> '+proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717 +x_0=400000
> +y_0=-100000 +ellps=airy +units=m +no_defs +nadgrids=OSTN02_NTv2.gsb'
> So it is using a gsb data file.
> The following query shows a difference
> converting a point in 4326 'WGS 84' to 927700 "OSGB 1936 / British National Grid"
> SELECT st_asewkt(st_transform(geomfromEWKT(
>    'SRID=4326;POINT(-0.077731 54.116851 86.778)'
> ), 927700)) AS a;
> postgres / postgis     result
> 9.6  / 2.3  SRID=927700;POINT(525745.680454343 470703.162768111 86.778)
> 9.6  / 3.0  SRID=927700;POINT(525744.779056573 470705.423178893 86.778)
> A difference of -0.901 2.26 which is quite significant given that OSGB
> is measured in meters.
> Any ideas what is going on?
> David McKelvie
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Raúl Marín Rodríguez
carto.com
