[postgis-users] ST_Intersection returning offset point on two lines which intersect
Paul Ramsey
pramsey at cleverelephant.ca
Thu Apr 23 12:02:43 PDT 2020
You don't. If you introduce a vertex into the original line at the intersection point, then the vextexes can match up, but the new point is not necessarily representable as being on the mathematical intersection of the two inputs, it's at the closest representable point.
This works, for example.
WITH lines AS (
SELECT
'LINESTRING(470874.945140537 6000126.53834916,470825.026548551 6000129.39039651,470813.970641131 6000131.67770864,470798.339625488 6000130.91512638,470770.509325729 6000128.62757298,470716.373201037 6000122.90909733,470592.358279565 6000112.18733429,470584.082725689 6000111.4719529,470471.616772575 6000098.31957132,470442.261380633 6000108.99375658,470402.993405271 6000132.6307069,470339.326451592 6000140.06487686,470261.553382752 6000143.87732586,470226.86058284 6000141.9710548,470158.999734862 6000139.4932543,470075.507824541 6000123.86262835,470042.340010929 6000112.04367615,470005.359698272 6000095.84140767,469987.441344206 6000088.9789069,469981.323382904 6000088.34605401,469976.38532627 6000087.83546738,469928.191247079 6000074.51890886)'::geometry AS l1,
'LINESTRING(470835.701330449 6000121.00308247,470835.612988186 6000125.16357655,470834.757333107 6000165.42524755,470834.681958091 6000168.96974537,470841.821713877 6000270.84345442,470838.892222296 6000668.7623786,470838.348652514 6000835.0334808)'::geometry AS l2
outputs AS (
SELECT
ST_Snap(l1, ST_Intersection(l1, l2), 0.00001) AS l1,
ST_Snap(l2, ST_Intersection(l1, l2), 0.00001) AS l2,
ST_Intersection(l1, l2) AS p
FROM lines
SELECT ST_Intersects(p, l1) AS p_l1, ST_Intersects(p, l2) as p_l2
FROM outputs;
> On Apr 23, 2020, at 11:42 AM, David Campbell <david.campbell at forcorp.com> wrote:
> Hi,
> I have two lines which intersect but ST_Intersection returns an offset point. Offset is around 0.000026m.
> WITH line1 AS (SELECT ST_GeomFromText('LINESTRING(470874.945140537 6000126.53834916,470825.026548551 6000129.39039651,470813.970641131 6000131.67770864,470798.339625488 6000130.91512638,470770.509325729 6000128.62757298,470716.373201037 6000122.90909733,470592.358279565 6000112.18733429,470584.082725689 6000111.4719529,470471.616772575 6000098.31957132,470442.261380633 6000108.99375658,470402.993405271 6000132.6307069,470339.326451592 6000140.06487686,470261.553382752 6000143.87732586,470226.86058284 6000141.9710548,470158.999734862 6000139.4932543,470075.507824541 6000123.86262835,470042.340010929 6000112.04367615,470005.359698272 6000095.84140767,469987.441344206 6000088.9789069,469981.323382904 6000088.34605401,469976.38532627 6000087.83546738,469928.191247079 6000074.51890886)') as the_geom),
> line2
> AS (SELECT ST_GeomFromText('LINESTRING(470835.701330449 6000121.00308247,470835.612988186 6000125.16357655,470834.757333107 6000165.42524755,470834.681958091 6000168.96974537,470841.821713877 6000270.84345442,470838.892222296 6000668.7623786,470838.348652514 6000835.0334808)') as the_geom)
> SELECT st_intersects(ST_Intersection(line1.the_geom, line2.the_geom),line1.the_geom)
> FROM
> line1
> JOIN line2 ON true
> https://gis.stackexchange.com/questions/359210/line-intersection-resulting-in-offset-point
> I have just tried to introduce ST_SnapToGrid, but all attempts at syntax still return false. in example:
> WITH line1 AS (SELECT ST_SnapToGrid(the_geom, 0.001) the_geom FROM (SELECT ST_GeomFromText('LINESTRING(470874.945140537 6000126.53834916,470825.026548551 6000129.39039651,470813.970641131 6000131.67770864,470798.339625488 6000130.91512638,470770.509325729 6000128.62757298,470716.373201037 6000122.90909733,470592.358279565 6000112.18733429,470584.082725689 6000111.4719529,470471.616772575 6000098.31957132,470442.261380633 6000108.99375658,470402.993405271 6000132.6307069,470339.326451592 6000140.06487686,470261.553382752 6000143.87732586,470226.86058284 6000141.9710548,470158.999734862 6000139.4932543,470075.507824541 6000123.86262835,470042.340010929 6000112.04367615,470005.359698272 6000095.84140767,469987.441344206 6000088.9789069,469981.323382904 6000088.34605401,469976.38532627 6000087.83546738,469928.191247079 6000074.51890886)') as the_geom) a),
> line2
> AS (SELECT ST_SnapToGrid(the_geom, 0.001) the_geom FROM (SELECT ST_GeomFromText('LINESTRING(470835.701330449 6000121.00308247,470835.612988186 6000125.16357655,470834.757333107 6000165.42524755,470834.681958091 6000168.96974537,470841.821713877 6000270.84345442,470838.892222296 6000668.7623786,470838.348652514 6000835.0334808)') as the_geom) a)
> SELECT st_intersects(ST_SnapToGrid(ST_Intersection(line1.the_geom, line2.the_geom), 0.001), line1.the_geom)
> FROM
> line1
> JOIN line2 ON true
> how do I get this query to return true?
> David
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
