[postgis-users] Can we treat a large block of psql codes as a string and execute the string?
Roxanne
rox at tara-lu.com
Fri Apr 24 06:38:28 PDT 2020
Shao,
Remember those $$ that start your clause are string escapes.
You can use another form inside your block instead of the quotes
such as
psqlstring := 'UPDATE' || output || $b$SET style_description = CASE WHEN descriptiveterm ~* 'Polygon Closing Link' THEN 'Polygon Closing
Line' ELSE 'Unclassified' END$b$;
On 4/21/2020 11:34 PM, Shaozhong SHI wrote:
> Hi, Giuseppe,
> See the following code to see what I am trying to do.
> DO $$
> DECLARE
> wccdate TEXT;
> output TEXT := 'public.topographic_line_buckinghamshire_milton_keynes_line';
> psqlstring TEXT;
> BEGIN
> execute format('ALTER TABLE %s ADD style_description varchar(50)', output);
> execute format('ALTER TABLE %s ADD style_code int2', output);
> psqlstring := 'UPDATE' || output || "SET style_description = CASE WHEN descriptiveterm ~* 'Polygon Closing Link' THEN 'Polygon Closing Line' ELSE 'Unclassified' END";
> psqlstring := psqlstring || "'," || " " || output || ")'";
> execute psqlstring;
> END $$;
> The other day when I composed a very long string to do something else, it worked.
> Now, I am trying to make update statement and then execute the string. But, I keep get error message saying the string gets truncated.
> Regards,
> Shao
> On Tue, 21 Apr 2020 at 23:09, Giuseppe Broccolo <g.broccolo.7 at gmail.com <mailto:g.broccolo.7 at gmail.com>> wrote:
> Hi Shao,
> Maybe you are looking about how to pass SQL statements via a shell here-document:
> psql [options] <<EOF
> SELECT *
> FROM foo1
> WHERE col='val';
> SELECT * FROM foo2;
> EOF
> Eventual bash variable within the here-document can be interpolated. To avoid that just quote the first instance of EOF
> psql [options] <<'EOF'
> SELECT *
> FROM foo1
> WHERE col='val';
> SELECT * FROM foo2;
> EOF
> Il giorno mar 21 apr 2020 alle ore 21:16 Shaozhong SHI <shishaozhong at gmail.com <mailto:shishaozhong at gmail.com>> ha scritto:
> It is quite appealing to wrap up a large block of psql codes as a string and execute the string.
> And, how to deal with quotes within quotes.
> I tried short text strings. It worked well, but it does not seem to work with very long strings in different lines.
> Can anyone shed light on this?
> Regards,
> Shao
> postgis-users mailing list
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/postgis-users
