[postgis-users] Various ways to handle addresses in postgresql
Stephen Woodbridge stephenwoodbridge37 at gmail.com
Fri Apr 24 21:08:47 PDT 2020
And I have create an address-standardizer project here
https://github.com/woodbri/address-standardizer which is user
configurable. I might be over kill is you just want to strip off the
number, in which case you might just use a SQL regexp replace to remove it.
-Steve W
On 4/25/2020 12:04 AM, Stephen Woodbridge wrote:
> PostGIS has address_standardizer extension that includes
> parse_address() and standardize_address() functions.
> -Steve W
>> maybe you can use the https://github.com/openvenues/libpostal library
>> with your favorite language bindings ( Python / Ruby / Go / PHP /
>> Node / R / Java  ...)
>> or as a Postgres database extension:
>> https://info.crunchydata.com/blog/quick-and-dirty-address-matching-with-libpostal
>> https://github.com/pramsey/pgsql-postal
>> Regards,
>>  Imre
>> Shaozhong SHI <shishaozhong at gmail.com
>> <mailto:shishaozhong at gmail.com>> ezt írta (időpont: 2020. ápr. 25.,
>> Szo, 2:49):
>>     I find this is a simple, but important question.
>>     How best to split numbers and the rest of address?
>>     For instance, one tricky one is as follows:
>>     21-1 Great Avenue, a city, a country, this planet
>>     How to turn this into the following:
>>     column 1,       column 2
>>     Note:  there is a hyphen in  21-1
>>     Any clue?
>>     Regards,
>>     Shao
>>     _______________________________________________
>>     postgis-users mailing list
>>     postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>>     https://lists.osgeo.org/mailman/listinfo/postgis-users
