[postgis-users] Various ways to handle addresses in postgresql
Shaozhong SHI
shishaozhong at gmail.com
Sat Apr 25 16:19:06 PDT 2020
Hi, Steve,
Many thanks. Please send me the link to parse_address() and
standardize_address().
I need to find these first before test-running.
Regards,
Shao
On Sat, 25 Apr 2020 at 21:20, Stephen Woodbridge <
stephenwoodbridge37 at gmail.com> wrote:
> Shao,
> '^( *Building *[0-9]+)?[- 0-9]*'
> or something like that should do it. But I think you will find that a
> more robust solution is to use parse_address() and/or
> standardize_address() as they will recognize a lot of other address
> constructs, like "apt 3a" for for example.
> parse_address() that a text field and breaks it into "house number
> street name" and "city state zip", but only works well in North America.
> standardize_address() that comes with postGIS, breaks the address down
> into its components and can separate out things like buildings, and
> apartment/unit specifiers so you can then take the fields you are
> interested in and recombine just them in a new string. Again, this works
> best in North America.
> My github address-standardizer is built to recognize address for most
> counties, but it can also be configured to recognize address standards
> for any county without too much effort. It compiles and installs as
> postgresql extension.
> Addresses are generally very messy and unless your addresses are vary
> simple you will be constantly fighting with this or that exception.
> -Steve
> On 4/25/2020 2:55 PM, Shaozhong SHI wrote:
> > Is there a way to left trim including the building and number?
> > Building 3 21-1 Great Avenue, a city, a country, this
> > planet.
> > How to take way those things which are too local to an address?
> > Regards,
> > Shao
> > On Sat, 25 Apr 2020 at 01:48, Shaozhong SHI <shishaozhong at gmail.com
> > <mailto:shishaozhong at gmail.com>> wrote:
> > I find this is a simple, but important question.
> > How best to split numbers and the rest of address?
> > For instance, one tricky one is as follows:
> > 21-1 Great Avenue, a city, a country, this planet
> > How to turn this into the following:
> > column 1, column 2
> > Note: there is a hyphen in 21-1
> > Any clue?
> > Regards,
> > Shao
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200426/77098295/attachment.html>
